Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
How do i replace Panasonic LSEB3131A Lamp Ballast
3 Suggested Answers
  • 3 Answers
SOURCE: Panasonic PT-45lc problem
I took the rear bottom off of the set,lots of screws to take off.
On top of the bulb housing is a small yellowish thermal fuse.
I took mine completey out,jumped the black wire together,and bingo.set works perfectly.
Posted on Apr 16, 2008
SOURCE: Need to buy a lamp & Ballast
http://electrified.com/Catalog/Items/?CampaignID=Froogle&ItemID=35508
Posted on Dec 20, 2008
Why red light is on ?
Its the most common poblem with the ax 100-200 projector.Many a times only the ballast requires to be replaced.yet on may occasions both mainboard and ballast requires replacement. its best to confirm with a good known working ax200 and replace first the lamp, ballast and the mainboard.panasonic ax 200 lamps also have failed premature as per my experience.
May 04, 2014 | Panasonic PT-AX200U Projector
Tip
Lamp vs Ballast
This is to help explain the short lives of Lamps.
WARRANTY: If a lamp fails within the first year replace Lamp and Ballast.
If Lamp explodes do not replace Ballast only lamp, but if lamp didn’t explode replace both.
If you experience more than one Lamp failure within one year of use replace the Ballast.
The Panasonic Brand offers a Ballast repair kit (LSUC0022), it only works about 20% of the time.
I would not recommend this replacement kit. It will get you past the 30-45 day warranty period in most cases but it will not be the proper FIX to the customer’s unit and they will only call you back or (most important) call another Service Center.
I have experienced maybe 100 customers that had other Service Companies come out and only replace the Lamp. When the Lamp and Ballast should have been replaced.
I hope this helps the Customers and the Technicians in their judgment.
If I was redundant I apologize, just trying to help.
Good Day, big IRISH
on Dec 09, 2009 | Televison & Video
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
TV shuts off by itself
I would think a ballast would be easy to change take out old put in new like for like
Nov 07, 2013 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-61DLX76-K TV, no picture, red lamp indicator flashes once every five seconds. Bulb looks okay visually. Panasonic says bad ballast I need confirmation and service manual.
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Dec 01, 2010 | Panasonic PT-61DLX76 Television
Panasonic pt-50lc13 it just will not turn on,but the red light is on and the lamp was replace
Is the lamp indicator light flashing? A new lamp may not solve the problem. The known problem with lamp failures is poor voltage output from the ballast,.. a problem Panasonic refuses to correct and they decided to no longer provide the repair part through their supplier in an attempt to sweep this problem under the rug.
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
Jan 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
The screen either does not come on at all, comes on after it warms us, comes on right away and then randomly fades to black, is black but audio can be heard. I just replaced the lamp but it still has the...
The ballast is the most common failure on these sets. The ballast is what supplies power to the lamp. If you physically see the lamp dimming/fading out when you loose the picture than the ballast is the issue. The ballast can be purchased from the following website. I would suggest a technician replace it as there are voltage charged up on it that are close to 400 volts. Please take a fe moments to rate my answer. Thank you...
http://www.partstore.com/Part/Matsushita/Panasonic/LSEB3131A/Recycled.aspx
Nov 18, 2009 | Panasonic PT-50LC14 50" Rear Projection...
My PT-61LCX65 all of a sudden turned itself off and the Lamp indicator LED is blinking once every 5 sec. It will not power up. Can it be the lamp?
That is most probably the lamp. In some case the lamp is fine and the problem is the lamp high voltage board (ballast board).
The most coomon is always the lamp. The lamp cannot be tested . The ballast board must be tested by a technician.
The normal operation in this case is replaceing the lamp that cannot be tested. then, if you are within that 2% of the cases with ballast problem you replace the lamp power board or call a technician.
You can find parts here.
May 03, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
PPT-50LC14
This points to a bad ballast and you need to have or replace this part. The ballast Pcb part number is LSEB3131A. This is the only solution given for this error code blink.
-Josh
Feb 08, 2008 | Televison & Video
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
