Question about Cartier Baignoire W15109D8 Wrist Watch for Men
Cartier Baignoire....how to replace battery - Cartier Baignoire W15109D8 Wrist Watch for Men
Coin battery for Cartier Argent 925
If your watch is a genuine Cartier, then you don't need to ask what battery it takes - you risk damaging the watch (at least cosmetically) and therefore devaluing it if you attempt to change the battery yourself. Take it to a professional, or reputable outlet to have them change the battery for you (ask them the battery type afterwards if you really want to know).
May 29, 2016 | Cartier Watches
How do i wind a Cartier ballon bleu watch
your watch is quartz that means its battery operated and needs the battery replacing
Oct 18, 2014 | Cartier W6920011 Watch Mens Ballon Bleu De...
HI I wont to know battery size to my watch must de cartier serial # 901014991
Not a good idea. What starts as a 'simple battery change' could result in $500 in repairs. It is a Cartier! If it is a fake Cartier then by all means destroy it. Just realize that you don't really know what you are doing and you are about to perform brain surgery on a very expensive watch.
Oct 07, 2012 | Cartier Watches
Greetings Folks. New watch, looses time by about 5 minutes a day. No mention of an adjustment for time drift and probably there is not one. So, new battery? This was new, out of the box, off the shelf at a...
hi
I appreciate your line of thought concerning the problem of your watch.
like you rightly mentioned before, it could be a battery prob;em which is usually the commonest for this error. so please change the batteries first then if the problem persist a simple service of the watch should solve the entire problem.
all the best
Aug 27, 2011 | Timex 27191 Wristwatch
My cartie santos galbee stops every so often. It has just had a battery replaced after being left unused for a year or two - any thought
According to their web site, this model has an automatic mechanical movement and therefore has no battery!
Is the number you quoted correct?
If you go to their web site Cartier.com? or Cartier.co.uk and look up your model (it is the last one in the group - go to the furthest right) and them click on details for that model, you will see a description of the watch.
If it is this model, (it will have "automatic" on the face), then it will only run for 2-3 days before stopping. To start it shake it gently from side to side for a few minutes.
Your replacement battery is therefore very puzzling!
May 05, 2011 | Cartier New Santos Galbee Xl W20099C4...
I haven't wear my cartier for a couple of days and is nor working i wear it for a few hours but still not working what should i do?
Hi , your Cartier is a quartz movement watch and does not need to be winded or worn in order to work. It does though need a battery. This sounds like your battery has died and needs to be replaced. Any jewelery or watch repair store will be able to change it out from the price of 8 -20 dollars please only go to an experienced jeweler though.
Oct 18, 2010 | Cartier Roadster Ladies W62026Y4
I need a replacement bracelet for my Cartier 21 Chronoscaph watch?
My black rubber watch band is cracked and in need of replacement. I refuse to shell out $500 for another rubber band from Cartier. This is my first and last Cartier watch... Poor customer service on a very expensive watch.
500 per one rubber; is not expensive is a steal
Sep 24, 2010 | Cartier 21 Chronoscaph W10125U2 Wrist...
Battery appears to have expired
Cartier have and "boutique finder" on their web site.
Go to http://www.cartier.co.uk/#/boutique-finder/australia and fill in your nearest city from the drop down list.
Jun 15, 2010 | Cartier Roadster W62016V3 Wrist Watch
I left the battery to long on my Cartier Santos and it no longer works. A jeweler sent it out and he says that it will cost $600. to clean up. He also says that the movement itself was not damaged, so it...
Most likely he sent it to Cartier. They charge about $400 to replace a battery. So the jeweler is marking that price up to you. If there is nothing wrong with the movement a new battery installed by a qualified watchmaker is much less.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 04, 2010 | Cartier Santos W20056D6 Wrist Watch
Cartier Baignoire W15109D8 Wrist Watch for Men Logo
Top Cartier Watches Experts
k24674
Jimmy Accardi
Are you a Cartier Watch Expert? Answer questions, earn points and help others
