Question about Intertherm Heating Cooling System 15kw Mobile Home Electric
Where is the drain pan on intertherm - Intertherm Heating Cooling System 15kw Mobile Home Electric
    Genius:
  • Intertherm Master
  • 1,363 Answers
Should be under evaporator coil.
Posted on Sep 16, 2015
I have a Intertherm model MGH-075-ABWN-05 and the A/C stopped working. someelectrical problem i'm guess.neither the blower fan nor the outside unit are running at all
Check the drain line for a float switch. Remove float and check for water. Do not leave float out, you must clear the drain. Good Luck
May 10, 2017 | Intertherm Heating & Cooling
Why does the A frame leak water
Check the drain pipe and the lining. It might have not been inserted and glued to the outlet from the unit.
Jul 20, 2014 | Intertherm Heating & Cooling
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
Drain pan
Hi.
Parts for this unit can be obtained contactingIntertherm or contacting this third party distributor HVAC Suppplies ' HVAC Equipment.
Call to find out if the drain pan is available.
Regards.
G.
Sep 20, 2010 | Intertherm P3RA-048K Air Conditioner
Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
Apr 07, 2010 | Intertherm P3RA-024K Air Conditioner
Water leaking onto floor
at night disconnect power use flash light and mirror check to see if coil is stopped up if unit is up flow coil fan heat kit make sure there is a trap in the drain line or unit will pull air into system most likley cause is dirty coil hope this helps unit could also have dirty fan blades low air flow or starting to freeze the coil due to low freeon charge if down flow supply duct under unit ths is not good due to heat kit on bottom of unit can get wet! hope this helps with your problem
Jul 04, 2009 | Intertherm P3RA-048K Air Conditioner
My central air conditioner which is 901282 Intertherm is rusted out and leaking. It looks like that the base can be replaced. Can you help me?
Yes, the base is called a pan and it can be replace with a plastic pan, or they have a liquid whic can be poured thru standing water and seal rusted pan leaks.. >Check out Palmer Supply in OKlahoma on the web-page but if you need the plastic pan check out the company of the unit web-page! Thank-you-very-much!
Aug 28, 2008 | Intertherm Heating & Cooling
Intertherm Heating Cooling System 15kw Mobile Home Electric Logo
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
