Nexbox3 message says, your set top is currently installing new software. a reboot may be necessary. how do we know when installation is complete?
  • 3 Answers
SOURCE: Installation Problem
Sounds like it could also be related to the possibility that the version you are trying to install is an 'upgrade' which requires the older version to be installed.
Posted on Apr 15, 2007
  • 110 Answers
SOURCE: Printer won't respond
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Posted on Aug 22, 2008
SOURCE: printer software will not install for kodak esp3se
I hate this printer. It does use less ink as advertised, but since I have unplugged it and am going back to my hp laser it will soon use no ink.
Try this to unstall the software:
http://www.kodak.com/global/en/service/downloads/private/xp_vista_98_ClearUtility.jhtml?osXPor98=winXP
this is the "clear utility" from the kodak site.
Posted on Jan 10, 2009
  • 414 Answers
SOURCE: Can't install printer software
follow the link to chat online with hp tech.
https://wimpro.cce.hp.com/ChatEntry/Chat.aspx?productOID=2512008&productLine=DU&productSNI=hpofficeje2511711&productName=HP+Officejet+Pro+L7580+All-in-One+Printer&productCategory=12019&SCOID=238445&h_cc=us&h_lang=en&lc=en&PSOID=2511708&lang=en&cc=us
i put that there because looked thru hp resources and they haven't had this problem.
Mark
Posted on May 07, 2009
SOURCE: instaal brian lara cricket 2007 it complete an d whwn i open it it says protection software is installed plz reboot after reboot the games does not open it blink and disappeared
copy all the files from the crack folder to its main folder
Posted on Jul 17, 2009
I want to change the background
Back up your files onto CD-ROMs or a flash drive. Have original copies of all the software you use as well, as it will need to be reinstalled after the new operating system is in place. In addition, any drivers for devices you have attached to the system will need to be backed up.
  • Insert the CD-ROM for the new operating system into the computer while it is turned off. Boot up to the CD. This may require you to enter into the system's CMOS and set up the CD-ROM drive as a bootable device.
  • Format the hard drive using the utility provided on your new operating system's CD-ROM. Most installation procedures will do this for you or walk you through the event. This will wipe out all information currently on your computer system, so it is imperative that you completed Step 1 beforehand.
  • Follow the installation instructions on your new operating system's CD-ROM. Advanced options may be available, but are only recommended for computer users with experience in installation of operating systems.
  • Reboot and reinstall old software and files from back-up copies, including software and drivers for devices you have attached to the computer. After all software and drivers are installed, reboot again. New drivers may have to be obtained from device manufacturers if the drivers you have currently do not work with your new operating system.please rate this post by raising the thumb up
  • Feb 04, 2011 | Computers & Internet
    I am trying to install an Java 6 update 20
    If you are using any form of Anti Virus software, it could be stopping the installation process. Go to the SUN Java website, and download the latest version. Save it to your desktop. Take a moment to reboot your machine completely. DO NOT start any other programs after rebooting. Stop or disable your ANTI VIRUS software. Install the JAVA update and reboot. The update should work, and upon rebooting after the install, your AV software should start again. If it is still disabled, enable it.
    May 03, 2010 | Sun Java Programming Language (cdj-275)
    Out of range message seen after installed new software and reboot
    The monitor will display out of range message because the PC video resolution is too high for the monitor to display, the new software may have changed or corrupt the video seting, try booting up in safe mode (hit f8 while computer booting up) and set the video resolution to 640 x 480, then reboot in regular mode, then reset the resolution to the native resolution of this monitor which is 1280x1024@60Hz.
    Mar 24, 2010 | ViewSonic VA703B LCD Monitor
    Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
    Try the following step :
    Pre-Installation Steps
    • Log onto PC with an account that has Administrative Privileges.
    • Disconnect ScanSnap scanner, if connected.
    • Close any open applications.
    • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
      • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
    ScanSnap fi-5110EOX Vista Update Pack Installation Steps
    1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
      1. ScanSnap Manager V3.0 – ssv3020up.exe
      2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
    2. Install all two update packs that were downloaded in Step #1.
      1. Reboot is NOT required after each update pack.
    3. Reboot the PC after all three update packs installed completely.
    4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
    Mar 07, 2010 | Fujitsu ScanSnap Manager
    Installed new video card, system reboots
    your current graphics card settings is not set to the correct level to match your system, you can download ATI Catalyst software from this link:
    http://support.amd.com/us/gpudownload/Pages/index.aspx
    after installing, you may have to restart your computer. when you restart, right click on the desktop and select (ATI catalyst), there you can adjust your graphic card features or you can use the recommended settings the software have adjusted for your graphic card by clicking on restore settings/defaults.
    you should not encounter problems once you have installed the ATI software.
    Sep 09, 2009 | ATI RADEON HD 2400 PRO Graphic Card
    Wireless mouse and keyboard issues
    If you have both sets of keyboard and mouse plugged in, turn off the computer and remove the old mouse and plug in the new mouse. Reboot and if necessary use the keyboard to login. Once windows is loaded let it detect the new mouse and then shut down again. Take out the old keyboard and reboot. You should now be able to use both new pieces without problems.
    Jun 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
    (french)i have bberry curve 8330 and i receive a eror code 205..
    If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
    Jun 09, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
    Installed WMP54GS and am getting the following error from Linksys Wireless Network Monitor Access violation at address 0040744D in module WMP54GSv1_1.exe'. Read of address 00000368
    Possibly you have installed the WLAN monitor also that is why it is creating the error...try these settings... Reboot your computer in SafeModeUninstall the software for the Adapter from start >> All programs/Remove the Drivers from Device Manager...Turn your computer Off and connect the adapter in a different PCI Slot...Reboot your computer in Normal Mode...
    >> Insert the Setup CD in the cd drive>> Click on Exit when the
    Linksys welcome screen appears>>Click on start. Unplug & replug adapter ...>> There should be a "" Found New Hardware Wizard ""
    that pops up on your screen>> Click on “Install software
    automatically “, and then click on next. Once the installation is
    complete>> Right click on the wireless network connection icon in the
    system tray besides the clock >>Click on view wireless networks and
    then connect to your network name...
    May 01, 2008 | Computers & Internet
    Usb flash drive will not install
    Try applying a small amount of pressure to the drive(up or down). The contacts might not be making a good connection. Have you updated the drivers for your pci to usb connections? Have you rebooted the machine with the dirve in the USB slot? Let me know what happens Tim
    Feb 16, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    Televison & Video Logo
    64 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
