Question about Uhu SAUNDERS CERVICAL HOMETRAC DELUXE
My pump is leaking - Uhu SAUNDERS CERVICAL HOMETRAC DELUXE
3.3l engine. What are the probable causes of DTC P1495?
answer courtesy of engine codes .com Engine-Codes OBDII Code List P1495 Dodge
P1495 Dodge P1495 Dodge - EVAP Leak Detection Pump Solenoid Circuit Condition 3 ' Add Comment Possible causes
- Faulty Leak Detection Pump (LDP)
- Leak Detection Pump (LDP) harness is open or shorted
- Leak Detection Pump (LDP) poor electrical connection
What does this mean? When is the code detected?
Malfunction is detected when the Powertrain Control Module (PCM) detected the pump solenoid did not change status when activated,
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible a noticeable fuel odor caused by the release of fuel vapors
P1495 Dodge Description
The Evaporative emissions system is design to prevent the escape of fuel vapors from the fuel system. Leaks in the system, ca allow vapors to escape into the atmosphere. The leak detection system tests for EVAP system leaks and blockage.
During the self-diagnostics, the Powertrain Control Module (PCM) first checks the Leak Detection Pump (LDP) for electrical and mechanical faults. If the first checks pass, the PCM then uses the LDP to seal the vent valve and pump air into the system to pressurize it. If a leak is present, the PCM will continue pumping the LDP to replace the air that leaks out. The PCM determines the size of the leak based on how fast/long it must pump the LDP as it tries to maintain pressure in the system.
Read more: http://engine-codes.com/p1495_dodge.html#ixzz3iQ8P3JII P1495 Dodge EVAP Leak Detection Pump Solenoid Circuit Condition
Aug 10, 2015 | Dodge Caravan Cars & Trucks
Onga 4352 Spa Pump is leaking from the opening in the bottom of the pump. I have opened it & siliconed the Oring seal but it continues to leak. Any suggestions?
I had a new pump brought to me once that continued to leak after replacing the shaft seal three times. Careful examination revealed a sand casting fault in the pump body. The water was leaking through the body of the pump. Have you replaced the shaft seal?
Nov 04, 2014 | Plumbing
What is a P2404 code mean from a suzuki sx4
Trouble Code: P2404 (2.0L L4 VIN 5 Automatic CVT)
Evaporative Emission System Leak Detection Pump Sense Circuit Range / Performance
Number of Trips to Set Code: 1
Trouble Code Conditions:
EVAP vent valve stuck open: EVAP leak check pressure is lower than -0.14 kPa even if EVAP vent valve is operated from OFF (OPEN) to ON (CLOSE) with EVAP leak detection pump ON. EVAP vent valve stuck closed: EVAP leak check pressure is unstable (difference between maximum and minimum is 0.36 kPa or more) when EVAP vent valve is OFF (OPEN) with EVAP leak detection pump ON. EVAP leak detection pump stuck OFF: EVAP leak check pressure is higher than -0.14 kPa even if EVAP leak detection pump is ON. EVAP leak detection pump flow high: Reference pressure of EVAP leak check pressure is lower than specified value (depending on BARO) EVAP leak detection pump flow Low: Reference pressure of EVAP leak check pressure is higher than specified value (depending on BARO).
Possible Causes:
  • EVAP leak detection pump (in EVAP leak check module) and/or its circuit
  • EVAP vent valve (in EVAP leak check module) and/or its circuit
  • EVAP leak check module and/or its circuit
  • ECM
Jul 11, 2014 | 2010 Suzuki SX4
I have a 1999 land rover a4.0 i have a coolent leak in the water pump area it dosent look the water pump is leaking
Confirm that the leak is not from the pump.. With the engine cold and off, clean all surfaces which are wet. Make sure the top of the engine is not wet as well. Start engine and look for where the leak is using a flashlight. Be careful of moving parts.
Water pumps have weep holes that leak when the pump bearing is faulty, small holes on the top/bottom of the pump. Also look for leaks from the hose connected to the pump.
May 06, 2014 | 1999 Land Rover Discovery
Leaking anti freeze from water pump screw
Most water pumps have a weep hole that leaks when the pump seal is broken. Usually indicates the water pump needs replaced.
Mar 01, 2014 | Dodge Shadow Cars & Trucks
How do I repair a leak coming from water pump gasket?
If it's leaking from the gasket you'll have to replace the gasket. If coolant is leaking from the hole in the water pump body the water pump seal is leaking. The pump will have to be replaced if the seal is leaking.
Sep 12, 2013 | 1999 Plymouth Voyager
Water pump
Could be either. Try tightening the clamp on the hose. If still leaking, probably the pump. There is a hole on bottom of pump behind the pump pulley, called a "weep hole". If the pump's internal seal is bad, this hole will leak coolant. Can you get a piece of mirror situated right to view this area? Or if you see white stains on the pump behind the pulley, that could be coolant leak.
May 17, 2013 | 2005 Suzuki Forenza
How do i replace the natural vacuum leak detection pump on a 2005 dodge dakota?
Vehicles equipped with NGC engine control modules use an NVLD pump and system. Vehicles equipped with JTEC engine control modules use a leak detection pump. Refer to Leak Detection Pump (LDP) for additional information.
The Natural Vacuum Leak Detection (NVLD) system is the next generation evaporative leak detection system that will first be used on vehicles equipped with the Next Generation Controller (NGC). This new system replaces the leak detection pump as the method of evaporative system leak detection. This is to detect a leak equivalent to a 0.020 (0.5 mm) hole. This system has the capability to detect holes of this size very dependably.
Removal & Installation
  1. Raise and support vehicle.
  2. Remove left-rear tire.
  3. Remove plastic shield (4) in front of left-rear tire. Access to both the EVAP canister (1) and NVLD pump (6) is from the area in front of the removed tire.
  4. Disconnect electrical connector at NVLD pump.
  5. Remove vapor line at NVLD pump. Pry outward on tab (3) and rotate pump (6) clockwise about 70 for removal.
  6. Remove NVLD pump O-ring (5) from EVAP canister (1).
To Install:
  1. Install new NVLD pump O-ring (5) to EVAP canister (1).
  2. Position NVLD pump (6) into EVAP canister (1).
  3. Rotate pump (6) until tab aligns with notch in EVAP canister (1).
  4. Carefully install vapor/vacuum lines to NVLD pump.
    WARNING The vapor/vacuum lines and hoses must be firmly connected. Check the vapor/vacuum lines at the NVLD pump, filter and EVAP canister purge solenoid for damage or leaks. If a leak is present, a Diagnostic Trouble Code (DTC) may be set.
  5. Connect electrical connector to pump.
  6. Install plastic shield in front of left-rear tire.
  7. Install left-rear tire.
    Fig.
    Fig.
Have a nice day (remember rated this help).
Mar 05, 2010 | 2004 Dodge Dakota
My 2006 charger 3.5 is leaking coolant but only somtimes is it a sign of water pump malfunction no indications on the gauges but car seems to be running hot
this is most likely the water pump if it is leaking at front of engine, the water pump is under the large timing belt cover and driven by the timing belt, so both are changed at the same time.
Feb 04, 2010 | 2006 Dodge Charger
Why is there a water leak coming from the water pump?
i would say you answered your own question, if there is water leaking from the water pump i would say the water pump is leaking and it needs to be replced,either the bearing is bad and its leaking out the shaft,or the seal is bad and its leaking outta there either way you need a new water pump,check the belt for wear when you replace it,,
Oct 07, 2009 | 1998 Dodge Caravan
Uhu SAUNDERS CERVICAL HOMETRAC DELUXE Logo
Top Uhu Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you an Uhu Luggage and Travel Expert? Answer questions, earn points and help others
