Question about Car Audio & Video
Subwoofer smoking I was playing my sub pretty good, not to loud but enough to feel it. all of a sudden some smoke started to come out, and I unhooked it, and took it apart, and plugged it back in, its working fine, for about an hour, no smoke..i wonder if I might have pushed it to far?
simplemitch
  • 752 Answers
SOURCE: subwoofer works at high volume, doesnt work at low volume
You had the settings set incorrectly and overdrove it. The voice coil leads are burn't open. If you look at the little flexible braids by the terminals I'll bet they are black/brown and maybe even burn't in half. It's toast.
Posted on Sep 22, 2007
shadow5599
  • 51 Answers
SOURCE: Smoke coming out of subs
If smoke has come out of the subwoofer, the speaker itself, that means the voice coils have been heated excessively and they are damaged or in this case, I'd say completely blown. Voice coils blow because they've been driven too hard, too much power, too much distortion for too long.
If you can get access to the front of the subwoofer speakers, gently put even pressure with your fingers near the middle of the cone, just around the edge of the centre dust cap and push gently and slightly inwards. If you hear or feel a "scratchy" type sound or feel, or if they dont move in freely, they are blown. And if that's the case, your amp could be damaged as well.
Most modern car amps have circuit protection and will shut down when they detect a load greater than they are used to so the amp MAY be ok. One way to test the amp is to hook another speaker to it, any speaker as a test is ok, and see if sound comes out. Make sure all power is off when connecting and disconnecting speakers!
Posted on Oct 17, 2007
Cerfer39
  • 709 Answers
SOURCE: subwoofer
Your overdriving the Subs and burning up the voice coils. Its really not worth fixing. It almost costs the same to fix as to buy a new one. Set you Amp gain down low. Then crank up the volume with a bass test. Slowly crank up the gain until you get some distortion. Then reduce the gain slightly. You will be set then to crank it up to the distortion level and not blow you speakers. Open a can of whoopass on anyne the cranks up on your gain. It will be costing you another set of MTX's.
Posted on Nov 24, 2007
pjstanley
  • 185 Answers
SOURCE: subwoofer stops working after awhile, but only one
it sounds like u blew them or the voice coils could be messed up here is one way to check take the woofer out of the box and look at the coils it should be ornge and then smell it if it smells like fire it might be going bad thats the reson it is frezzing like that let me no what happens and please rate me
Posted on Apr 07, 2008
SOURCE: JL 12W2 Subwoofer
Happened to me, i also had a metallic/iron smell coming from my sub... i pronounced it dead. had to buy a new one and it worked fine... if you believe its not dead then your amp is not getting enough power and most likely shutting off (protection mode), you can try buying a cap, farad 2 or better will work and is suggested for larger subs anyways
Posted on Jan 14, 2009
I have a 2005 Polaris Sportsman 800 EFI and it suddenly started running rough and started smoking. .
If gasoline is left sitting for a while (2-3 months) it attracts water, which could cause the "smoke" and rough running engine.
Unless it is a 2 stroke engine, no oil should be coming out the exhaust. Hold a clean rag or a bunch of paper towels at the exhaust opening BE CAREFUL NOT TO BURN YOURSELF and than check if, whatever the rag or paper towels catch is oily. If it is a 4 stroke engine, and oil is the exhaust fumes, a seal inside the engine is gone and has to be replaced.
Jan 06, 2014 | ATVs
I have a single 15" sub woofer in a box it was
Simply put, burned voice coil. Either too much power can do this or not enough power with distortion. solution- if the sound is clear then its too much power- turn the amp down. If the sound is distorted and raspy- its not enough power and your getting distortion-get bigger amp.
Jan 07, 2013 | Car Audio & Video
Not loud enough at max volume
The computer sound card has to have enough umph to drive the speakers. Most Netbooks and some laptops just don't have enough power to create loud sound.
Sep 24, 2011 | Logitech S120 2 Speakers
I had my boss 2400 watt 2 channel amp hooked up in my car. I had one sub on each channel and one of my subs blew. I unhooked the positive speaker wire on the blown sub, everything was fine. Driving down...
If your amp started smoking, probably not. Due to your description, did the other sub really blow? I would hook it up to another amp to test it. It may have been a channel in your amp. As for repairing the amp, the parts and labor to repair will probably cost you more that to just replace the amp.
Sep 06, 2011 | Boss Car Audio & Video
Jl 12w3v3 started smoking after hookup
Dang man you roasted it, take it in and get it replaced.Check the gain on the amp try it at 1/3 to 1/2 gain and dont crank up the bass boost all the way try it at like 2/3 that should clean up your sound and cut down distortion-distortion kills subs by heat.
Jan 31, 2010 | Jl Audio 12W3v3-4 Car Subwoofer
Subs will pound then suddenly stop, when you turn the ignition back they will sometimes start to pound.
What you must do is check the amplifier when they stop playing.
Check wether the amplifier is not in protection.
If it is feel how hot the amplifier is. You may have the subs wired incorrectly to the amplifier.
Check the thickness of your power cabling. If it is not thick enough then the amplifier will also go into protection.
IYou can also try disconnecting 1 of the woofers to see if maybe you dont have a faulty sub.
Nov 07, 2009 | Dual Car Audio & Video
My subwoofer started smoking-
a usual problem of a subwoofer just like my old sound system. Subwoofer generates a big heat on its device unlike ordinary speakers. better to send that to a technician to change a spare parts. it must be an ic problem got damage by over using.
thank you for using fixya
CHARCOIS
Nov 02, 2008 | Altec Lansing 641 Computer Speakers
Speakers are smoking
Do they still play? if they do then don't turn them up so loud. What that smoking is, is the coating on the voice coil turns being burned off. It happens when you are over powering or distorting the speaker very heavily. I would recommend more easy listening. Good luck.
-Andrew Hawkins
Sep 04, 2008 | Car Audio & Video
Oct 17, 2007 | Jensen JX1200 Car Subwoofer
Speakers keep cutting out and the box starts smoking...
Most likly if its smoking, and you replased your wires then your speeker coweols may have moved together from overdriving the subs and are slighly tuching. Wich would mean you need to just get new ones. Im looking to buy some of theas and that is something severol people have been having problems with from over driving the subs. ps. sry bout the spelling, lol
Nov 20, 2006 | Dual XINBP212 Car Subwoofer
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
