Question about Garden
I have an EXCEL EXWGV2121 pressure washer. The soap dispenser doesn't work. I have removed the pump manifold and can see rust in it. How do I remove part number 42 - injector nipple so I can clean it?
  • 92 Answers
SOURCE: Can't fine where to put pump oil in
Dear glenoaks06,
I handled various Karcher washers, but the 2500 I never came across it. Just the same I will give you a few hints and maybe the solution for the problem. When the oil is milkey this means it has water in it. This means that there are faulty seals for sure. Now in many Power Washers the compartment where the oil is located is filled with oil prior to assembling the head unit that contains the pistons. So you have to take apart the the complete head change all seals( HP seals, LP seals and OIL seals). There are pumps that take multi-grade oil(15/50) and others 90 grade oil. If your pump is fan cooled, it probably takes 15/50 oil. Now one of the main biggest problem of water in oil is Faulty and Scratched PISTONS.
So when you have the pump apart....check condition of pistons. It is useless to change seals if pistons are damaged.
Now one thing regarding your problem, is that you have to put together the head with the pump upside down, so that you can fill the compartment (where the pistons are pushed by the swash plate), with OIL, before you put back the complete head with good pistons,springs,seals, valves...etc..etc. These few hints are relevant to quite a number of Karcher washers.
Regards,
Fulltech.
Posted on May 22, 2009
  • 384 Answers
SOURCE: pressure washer won't pull the from the soap dispenser
Nozzle dirty, clean out nozzle with small diameter wire. Soap dispensing only happen at nozzle low pressure setting
Posted on Jul 27, 2009
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Posted on Jan 30, 2010
  • 68 Answers
SOURCE: I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Posted on Feb 08, 2010
Testimonial: "I'm sure the answer is correct. Over time my use of harsh chemicals no doubt corroded the key-way."
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Posted on Aug 09, 2010
The low pressure soap dispenser doesn't work. I have removed the pump manifold and it is full of rust. I do I remove the injector nipple from the pump manifold to clean it?
To properly fix this you will need to disassemble the hose and fittings, Clean them throughly and replace the hose. Also I suggest that the fatory filter be replaced or a small screen is placed over the line again.
Many of these filters are renoved because they don't fit into soap bottles.
Oct 18, 2013 | DeVilbiss Pk17374 Pump For Excell...
How do i install my soap dispenser into the 1600 all-power electric power washer
There should be a 1/4" hose nipple on the pump which will connect to the soap dispenser with a 1/4" line.
Sep 28, 2013 | All-Power America Garden
How to get soap to come out of dispenser of mcculloch power washer fhh 18a
Most people make the mistake of using a high pressure tip on their power washer while trying to get the soap dispenser to work. These tips are usually red, green, white or yellow and they cause too much back pressure at the dispenser for it to work. You need to use the soap tip, they're usually black, for the dispenser to work properly.
Jun 17, 2012 | McCulloch Garden
Can't get soap to feed into system
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jul 04, 2010 | McCulloch FHH18A Electric Pressure Washer
No high pressure water
Jul 01, 2010 | Karcher 1550PSI Pressure Washer
Pressur not costant
Jun 21, 2010 | Karcher K2.26 Electric Power Washer
It will not dispense the soap.
You need to adjust the nozzle on the end of the lance so the machine will draw chemical at low pressure.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
Pump working - no pressure from hose. B2002?
Sounds to me that you may have a blocked high pressure jet.
Dec 13, 2009 | Karcher K2.26 Electric Power Washer
No pressure on simoniz gas pressure washer
May 03, 2009 | Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
