Question about Nokia E63 Cell Phone
Removing encryption key - Nokia E63 Cell Phone
  • 46 Answers
To open a locked memory card, select Options > Unlock memory card. Enter the password.
If you cannot recall the password to unlock a locked
memory card, you may reformat the card, in which case
the card is unlocked and password removed.
Formatting a memory card destroys all data stored on
the card.
Encryption
Select Menu > Tools > Encryption.
Encrypt your device or memory card to prevent
outsiders from accessing your important information.
Encrypt device memory or memory card
To encrypt the device memory,
select phone memory.
To encrypt the memory card, select memory card from the following:
Encrypt without saving key
• memory card without saving the encryption key. If
you select this option, you cannot use the memory
card in other devices, and if you restore factory
settings, you cannot decrypt the memory card.
Encrypt and save key
• and save the key manually in the default folder. For
security, store the key to a safe place outside the
device. For example, you can send the key to your
computer. Enter a pass phrase for the key and a
name for the key file. The pass phrase should be long
and complex.
Encrypt with restored key - Encrypt the memory
• card with a key you have received. Select the key file,
and enter the pass phrase
Posted on Nov 01, 2013
  • Lorena Pagulayan
    Lorena Pagulayan Oct 27, 2016
    where do i fine the Option>unlock Memory card on my phone which is Nokia 701?
Remove encryption
Unless you have the encryption key you can't access the data.
Apr 07, 2014 | Electronics - Others
I tried to change from WEP to WPA but the password will not go through. It makes it an unsecure line for wireless. What am I doing wrong?
The Short Answer:
Your password might not meet criteria. It also depends on whether you use a custom encryption key. If so, then you either need to create a 10-digit or 26-digit hexadecimal number (numbers 0-9 & letters a-f) depending on whether you use 64 or 128-bit encryption.
The Long Answer:
A WPA password must be between 8-63 characters long, and must only contain ASCII printable characters.
The 2Wire User Guide for the 2700 states the following:
"You can customize the following wireless settings in the Wireless Security panel.
1. From the Authentication pull-down menu, select an authentication setting: WEP-Open, WEP-Shared, or WPA-PSK.
Note: WPA-PSK authentication is supported only on HG model gateways.
Open authentication allows users to configure their wireless adapter as either Open or Shared; in either case an encryption key is required. Shared authentication allows users to configure their wireless adapter for Shared authentication, which requires an encryption key. WPA-PSK requires that users configure their wireless adapter using TKIP.
2. To use the encryption key that came with your gateway, click the Use default encryption key radio button.
To create a custom encryption key, click the Use custom encryption key radio button. If you select Use custom encryption key, you can define a 64-bit or 128-bit encryption key. For 64-bit encryption, enter a 10-digit hexadecimal number. For 128-bit encryption, enter a 26-digit hexadecimal number. A hexadecimal number uses the characters 0-9, a-f, or A-F.
3. Click SAVE"
May 04, 2011 | 2wire 2700HG-B Router (2700HGB)
I use a Motorola XTS 5000 2 way radio at work. It displays a message "Key Failure"' and intermittenly beeps. It will not allow transmissions. Can I program a fix or does it need to be repaired?
It needs to be looked by a programming technician in a radio shop. "Key Failure" means that a secure encryption key has not been loaded into the radio and you have set the switch for using encryption to the "on" position. This switch is located under the channel switch on top of the radio and in your case it should be set to the "O" position and not the "O" with the line through it. The XTS radios can be programmed to retain the encryption key when the battery is removed OR to keep the key even if the battery is removed, so it depends on how your radio was programmed as well.
Mar 25, 2011 | Radio Communications
Are trying to enter the WEP key and it is not allowing any more the 5 characters (please input 64 bit WEP encryption and Five ASCII Characters))
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption.
Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead.
Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
Click here if you cannot access the web-based configuration.
Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key.
Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption.
  • 64-bit encryption 10 characters
  • 128-bit encryption 26 characters
  • 256-bit encryption 58 characters (available on DI-614+ only)
    The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key).
    Step 5 Click on the Apply button then click on the Continue button to save your settings.
  • Jun 25, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Contacts locked with menc file extension
    You will be able to tell the difference when you can remove the storage card and insert it in another device or card reader. Encrypted files will be displayed as .MENC files, with the following filename convention:
    [filename].[extension].[GUID].menc
    The [GUID] is the encryption key that determines whether the file can be decrypted on the device where the storage card is inserted. The .menc extension is the indicator that tells whether a file is encrypted. The purpose of the extension is to indicate that you can't open those files. A Lock icon is also associated with the encrypted files.
    When you insert the storage card back to your device where the files were encrypted, the [GUID] will match with the decryption key on your device and the [GUID].menc extension will not be displayed. Encrypted files will appear just like normal files and they can be opened.
    Mar 05, 2010 | HTC Hero Smartphone
    Pls i need 2wire299 wep key
    The WEP encryption key is configured in the wireless router.
    Go to the router's wireless configuration to view this key and you can then configure the wireless card with this encryption key.
    If you cannot see the key you can setup a new encryption key and the configure the wireless card with this encryption key.
    Sep 30, 2009 | 2wire Computers & Internet
    Have AT&T 2WIRE849 modem. Need WPA Key Code (alpha only encryption) for notebook PC. How do I secure WPA Key Code for modem service
    The WEP and WAP key is configured in the wireless router settings, you create the WAP encryption key and use this key to configure the wireless card in your computer.
    WEP is not a very strong encryption key compared with WAP and WAP2, I suggest you use WAP2 if possible. You can create the encryption key with alpha and or numeric keys, if you want to use words or phrases to create the encryption key then use the PASSPHRASE.
    Sep 28, 2009 | AT&T Computers & Internet
    WEP Encryption
    It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
    Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
    WEP Encryption
    Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
    Nokia E63 Cell Phone Logo
    229 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
