Question about Umarex Elite Force M4 CQB Sportline Carbine AEG Airsoft Gun
I need to find the serial number on my elite force m4 cqb aeg, can anyone help me?
Adobe audition cs6 serial number
i need a working serial number for Adobe Audition cs6... could anyone please help me out here???
Jul 14, 2013 | Adobe Computers & Internet
My AEG oven needs a PC board, but I cannot find where I can buy one. Can anyone help pleases?
PCB for D5701-4-M is obsolete. I certainly could not find one. Alternative is repair. I used QER Ltd via ebay. Involves removing and identifying part number of board and ordering repair via ebay listing. The trick is to find the correct listing for your board number as it will not be listed under AEG D5701-4-M. For instance, my D5701-4-M, part no. 944171390 (found on plate in bottom right hand corner of main oven) uses board NPPUGN104. It was listed in ebay under Repair pcb / module Zanussi Z0B1060X. Took two attempts to fix, but so far so good.
Nov 19, 2012 | AEG D5701-4 Electric Double Oven
C-3c50
C3C50 at power up.
PROBABLE CAUSES:
1. Loose connectors or failed PWB-C board.
Reseat all connectors and then replace PWB-C board (p\n 65FA-9360) if necessary.
2. Poor connection for the interface cable between the MFP and scanner.
Reseat the MFP-to-scanner interface cable its a large molex cable with thumb screws to remove on the outside of case.(p/n 4581-6876-01).
3. Failed PWB-F board.
Replace PWB-F board (p/n 4025-0103-27). Flash MFP with most current firmware. The latest version firmware or system software is available via the Konica Minolta Download if you need help with this write me back.
4. Incorrect scanner serial number.
Access service mode and select System Input. Verify the correct scanner serial number has been input under Serial # Input.this is in Service mode. if you need help with this write me back
Nov 29, 2011 | Konica Minolta Minolta CF 2002 3102...
Seems like my ex has intentionally changed or removed the electrical wires from my w 1540 washing machine... now i would like a service manual or pictures how to connect the wires (top)
Are you in UK using 220V AC or in USA using 120V AC?
Service & Spare Parts
If after carrying out the necessary checks there is still a fault with your appliance please contact your local AEG Service Force Centre. In guarantee customers should ensure that the suggested checks have been made as the engineer will make a charge if the fault is not a mechanical or electrical breakdown.
Please note that proof of purchase is required for in-guarantee service calls.
Service & Spare Parts If you require a service engineer or wish to purchase spare parts, contact your local AEG Service Force Centre, by telephoning: Help us to help you Please determine your type of enquiry before telephoning. When you contact us we need to know. 1. Your name, address and post code. 2. Your telephone number. 3. Clear and concise details of the fault. - What is the fault? - When does the fault occur? 4. The model, production number and product identification number. 5. Date of purchase. This information can be found on the rating plate, so you have these numbers to hand we recommend you write them below. Customer Care For general enquiries regarding your AEG appliance, or further information on AEG products please contact our customer care department by letter or telephone at the address below or visit our website at
www.aeg.co.uk.
Customer Care Department AEG Domestic Appliances 55-77 High Street, Slough, Berkshire SL1 1DZ
Tel: 08705 350350*
*Calls to this number may be recorded for training purposes. 0870 5 929 929
Here is the FULL User Manual Link HERE
UK parts site
Link HERE
Jan 30, 2011 | AEG Lavamat W1450 Front Load Washer
Dishwasher dispenser not opening
Would need the model and serial number to give more details but, in most cases it is due to a fault trip arm located inside the door. sometimes repaired without new parts. also may be a faulty timer. hope this helps. If you would like to send me those numbers I will look into more information for you.
Dec 20, 2010 | AEG Dishwashers
Bellow for Kenmore Elite front-loader washer
The Bellow should be available at a appliance part store. be sure to call with the model number and serial number, that way if they don't have it they will have time to order it.
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
Can't get my m4 mower to start for more than 5 secs
The 153 is the first part of the model # example 153-xxx, This is the prefix for MTD mowers.
Yoy can find the approxamate year by looking on the engine. The serial number usually has a date code. Like briggs and stratton will have a model # like 125K02 0245 E1 04218 53 the last two digits are the manufacturing facilty, The numbers before that are the date code 04218 means 2004 Feb. 18 was when the engine was made.
You can go to MTD's website and do a prsts search and it will ask for appx. serial number like the 153- xxx this will take you to an illistrated parts list as well as an owners manual.
Jun 09, 2009 | Mtd 22" Yard Machine Push Mower
Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Nov 17, 2008 | AEG B1180-4 Electric Single Oven
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Umarex Elite Force M4 CQB Sportline Carbine AEG Airsoft Gun Logo
97 people viewed this question
Top Umarex Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Umarex Optic Expert? Answer questions, earn points and help others
