Question about Health & Beauty
Jazzy select GT, fully charged, controller(joy stick) will not turn on-no power
5 Suggested Answers
dromtonpa
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
SOURCE: Jazzy 1121 power chair won't go
If your chair is run by a Pilot VSI controller, the error code----3 red/4 yellow/ 1 green---indicates a controller failure. I am having controller problems of a different kind on a Jazzy 1107 and it appears that few shops will work on the controller. Replacement is very costly.
Posted on Apr 14, 2009
  • 175 Answers
SOURCE: Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
Posted on May 23, 2010
SOURCE: Jazzy 1103 The led charge indicator quit months
turn it on then push the joystick forward till it beeps then pull it backward till it beeps then it will unlock. chair is in lockout mode
Posted on Jun 16, 2010
I have a jazzy Select GT power scooter, on the charger I have a red light and green, I put it on charge and have both green lights on now but the controls near the joy stick and on and off light nothi
need more info on equipment to answer ,scooters dont have joystics powerchairs use joysticks if you have a powerchair that has not been charged for over two weeks the batteries have probably died
in this state the charger will not go into charge mode only the power light and poss the fully charge lights will light
as a quick test a 24 volt bulb from a scooter or lorry with 2 wires attached pushed into the two outer holes in the joystick charge socket should light up if it wont batteries are totally dead
Nov 21, 2014 | Health & Beauty
I jhave a Jazzy Select GT power chair, I put the charger on it when the light shown red and green, when it powers up when charged the both lights will turn green, but now it will do nothing with start
Hi Gloria,
The first thing you need to do is measure the voltage at the charging socket of the Joystick (outside 2 pins). This will determine a lot of things, so I can guide you further.
Nov 21, 2014 | UPG 12V 35AH Jazzy Select GT Power Chair...
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
How do you power on the jazzy select chair?
There is a sequence of a button push while moving the joy stick in a certain direction untill it beeps. Check the owners manual for the exact sequence. You can download the manual from Pride's website.
Jan 08, 2014 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy 1113 power chair shows charged but control light is blicking. Chair will not move.
It appears that the controls are in Lock Mode. Unlocking Instructions depend on your type of controller. Go to PrideMobility.com to download the proper manuals for chair and controller.
Feb 11, 2013 | Pride Jazzy 1113 Power Chair
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
How do you hook up to charge a jazzy 600 wheelchair
your charger plug fits under the controller joy stick. It has 3 coverd prongs smithrm70@hotmail.com
Nov 18, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Health & Beauty Logo
57 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
