Question about LG WM-0532HW Front Load Washer
Control panel malfunction, cannot change options
Each of my 7 cyles is frozen and cannot be changed. None of the option buttons respond when pushed (except delay wash).
  • Anonymous Apr 01, 2014
    Control panel buttons difficult to push to change cycle options
  • 489 Answers
You have a failed display board and it will need to be replaced.
Posted on Apr 28, 2008
SOURCE:
Aqualux Whirlpool Bath controls not responding
Unplug, every thing, take batteries out of remotes etc, remove power from all parts.I mean every parts. leave out for about a minute. reconnect all. try then
Dec 02, 2013 | Home
Aqualux whirlpool bath
The panel has failed and it is unlikely that it was your dogs fault.
Dec 02, 2013 | Washing Machines
Left click will not work
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar . Or disconnect the mouse from your computer restart.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Hope this helps.
Jan 23, 2013 | Toshiba Satellite C655-S5123
How do you change your area?
For Windows XP : Hit start button, select "settings", then "control panel" and select "Regional and Language options". Then Change it from English(Canada) to English(United States).
For Vista and 7 : Open Regional and Language Options by clicking the Start button, clicking "Control Panel", clicking "Clock, Language, and Region", and then clicking "Regional and Language Options". Then Change it from English(Canada) to English(United States).
May 21, 2012 | Acer Aspire 5732Z-4855 Notebook
I want to change the language of pc
go to start -->control Pannel --> Reginal and Language Options and from Regional Option Tap change the Language to the Language you want
Jul 12, 2011 | Computers & Internet
The control panel does not seem to work on the door. None of the switches work, ice,water, options, alarm. The change filter sign on the main display is highlighted. I tried turning the refrigerator...
Yes the filter needs to be changed after the change filter light is indicated.After changing the filter the unit has to be reseted.The reset procedure is as follows:--- press and hold the Water Filter Reset button for 5 seconds. Newer models: press the Options button until "filter change" is selected, press selection buttons +/- until the "filter change" display goes out.-------------------- Thank you.
Jan 31, 2011 | Siemens KA62DV50GB Side by Side...
Washer options not working on control panel. The options that aren't working or responding to controls are: presoak, stain cycle, extra rinse, heavy soil, normal soil, light soil. Other options work and am...
when you push the button to select the options that arent working do the lights at the selected option come on? if they do not then you need a new control panel they will cost you approx 100$ to sell it as is you would be lucky to get rid of it, they only last for 7 or eight years max anyway before the outer tub bearing fails.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dishwasher does not start
I have the same problem. I've tried everything;even took apart the control panel and checked for corosion. I ended up changing the control board-$130 down the drain- The only other thing I can figure is the button panel has some sort of short- also ~$130-. good luck. Now I use the sink (wife's not happy) Tech sheet is behind kick plate.
Dec 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Some buttons do not work in game
Well, assuming FIFA 09 is compatible with joysticks/controllers, in the Options menu of the game, where you change the controls, you should be able to assign those unused buttons to actions.
Hope this solved your problem
- Josh
Oct 20, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Washing Machines Logo
100 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
