Question about Monster Cable ConnectAll 200 (126123)
How do I connect the Monster Cable ConnectAll 200 to a DVD Player when there is no TV imput so I can watch DVDs on my TV set?
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
Setting up HDMI / DVI port as a selectable Imput
may i know the model and maker of the device you want to use a HDMI cable
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
My Panasonic viera TX-26LXD70 says that there is no DVB service found and to check my aeriel or Local DVB service availability. There is no socket to put the co-axial cable in the tv. The tv still works...
Use HDMI from the DVD player and hook up the antenna to the TV..... or DB9 connector on TV.... DO NOT watch DVD from a D VD player or compost cable from the DVD it looks like junk. consult manuel how to hook up your TV
Feb 27, 2014 | Panasonic Televison & Video
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
Do I need to tune my tv to watch a dvd? I have connected my dvd player to my tv (I don't have an ariel, I simply want to watch dvds) do I have to tune my tv and if so, how do I do this?
No, the dvd player is totally separate. you will not need to tune your TV, just plug the DVD player in via a scart or an HD socket, and run through your channels till you find which one it is on :)
May 16, 2009 | LG GSA-E10L (8801031212552) DVD±RW Dual...
How can i connect the dmres15 to my cable box, dvd/vhs player
Yea I have the same set up and did the same thing as that your trying to do and what you have to do is run both the cable box and the VCR through your TV using the inputs. As well as a PS2 running through imput 3.
Hope I helped
Jan 30, 2009 | Panasonic DMRES15 DVD Recorder
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
Can I play the video and a dvd without the remote control?
Your set should have external video and audio imput jacks besides the tuner imput for antenna,you can use the video and audio outputs from the vcr or DVD and conect them to the video and audio imputs in the tv then you can select a channel below 1 or push the switch that says Video/antenna.
Oct 02, 2006 | Samsung CXD2512 25 in. Combo
Monster Cable ConnectAll 200 (126123) Logo
32 people viewed this question
Top Monster Cable Televison & Video Experts
Electro Med Services...
Are you a Monster Cable Televison and Video Expert? Answer questions, earn points and help others
