Jenn-Air 400 Watts Attrezzi JSM900 Stand Mixer
Problem for Jenn-Air 400 Watts Attrezzi JSM900 Stand Mixer
Mixer doesn't run
By johndo on Sep 26, 2007
The lights come on but the motor doesn't start. I have removed all the screws I can get to but the mixer won't come apart. I would like a suggestion as to how to get it apart, or where I can get a parts diagram. I have tried several online parts listings with no luck. (my model is XAAS)
Same Problem
Dec 28, 2008
-   Mixer ran for twenty seconds and stopped, lights are on...Please help.......-   Guest
Jan 14, 2008
-   I have the same problem. Mi-   Guest
Best Solution
posted on Jun 12, 2008
Very Helpful)
jumbo373
Rank: Apprentice
Rating: 95%, 3 votes
you can take it apart by removing the pin which is in the shaft that does NOT hold the attachments....... i got mine out with a nail set and a gentle tap or two with a hammer. after you remove that pin the portion that holds the attachments will slide down revealing three more screws and some gearing. if you remove those three screws....... the top will come apart (assuming you have removed the other four screws which are visible when the unit is assembled) and you will see the circuit board.
Was this helpful?
Yes
No
Solution #2
posted on Jul 19, 2009
Not Rated)
maverick_bea
Rank: Wiz
Rating: 83%, 81 votes
there's 2 short screws that you can see. on the shaft of were you put the attachments, there's a c clamp that you need to take off and there's a pin that you have to punch out ( be sure to save these parts ). once you get this off you should see the gears, on the outer side of the machine there will be 2 more screws but they will be longer( don't take the screws out that are in the gear area ) and the top should come off then. when you look inside, you should see a micro switch that is located where the two haves meet. sometimes there's a piece of metal that is held down by a brass screw that doesn't engage the micro switch. the way i fixed mine was to fashion a new piece. ( make sure that the piece engages the switch when you put it in the down position ). reverse your steps to put it back together and test.
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air 400 Watts Attrezzi
Questions and Unsolved Problems for Jenn-Air 400 Watts Attrezzi
Do you recommend Jenn-Air 400 Watts Attrezzi JSM900 Stand Mixer?
Answer
Answer
I would like to print a manual for Jenn-Air Attrezzi Mixer. Model JSM900GAAU
Answer
The hook inside the blender that holds the head up when you are not using or to remove the bowl is... (More)
Answer
When mixing a moderate dough, the head on the mixer will move up and down and makes a bump noise.... (More)
Answer
I purchase this item and was trying to use it for the first time, the light comes on but it was... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jenn-Air 400 Watts Attrezzi...:
Top Mixer Experts
Rank: Guru Guru
Solutions: 2543
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Mixer Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
