Red key on digital display Samsung washing machine
2 Suggested Answers
  • 5105 Answers
SOURCE: How to turn off child lock on WTG7532W lg washing machine
Try pressing and holding the Rinse button (between the Wash and Spin buttons) for 3+ seconds. This should toggle the Child Lock off and the Start button should work to resume the cycle. (If you have touched the Power button, you may need to turn on the washer first. The Child Lock feature remains in the last used state.) See page 27 of the Owner's Manual for information on the feature. The manual is available from the manufacturer's support page: http://www.lg.com/au/support/support-product/lg-WTG7532W#manuals . The current link to the manual is http://www.lg.com/au/lgecs.downloadFile.ldwf?DOC_ID=20150102039896&what=MANUAL&fromSystem=LG.COM&fileId=SVYMjStXlkiH8PNt0qdVA&ORIGINAL_NAME_b1_a1=MFL67568754-Eng.pdf .
If you can't get the Rinse button to respond, you may have a problem with the touch pad circuit board, the wiring between the touch pad and the control board or the main control board.
I hope this helps.
Posted on Apr 08, 2017
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Fitting a motherboard to my Samsung WA13V5.There is a terminal under the digital display that does not have a visible matching plug. The motherboard part number is DC92-00278L.
    The controller may be applicable to a number of models, depending upon how it is configured. Your washing machine may not use that terminal.
    Jun 20, 2016 | Samsung Washing Machines
    How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
    Obviously, an alarm is displayed after some time.
    The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
    • button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
    • button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
    Dado
    Jun 10, 2016 | Electrolux Washing Machines
    Hi I have a hoover vhd 9143 zd washing machine which went 'pop' today. Now it doesn't work and the red digital display does not work properly? Any suggestions?
    unplug the unit then remove the cover and look for the circuit board which get wet.or a wiring that get loose connection.
    Oct 15, 2012 | Washing Machines
    I have a samsung smart wash B1245S 6kg . when i set it on for a quick 30 min wash it will fill with water for about 10 mins . Then it will cut out and 4E will flash up on the digital display
    Display shows 4E.
    Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
    Dec 17, 2010 | Samsung Washing Machines
    I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
    WATER DRAIN ERROR - Display shows 5E.
    5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
    Dec 11, 2010 | Samsung Washing Machines
    My top loading machine always stops on Rinse
    Did you find a solution? Mine is doing the exact same thing : ( Thanks.
    Mar 22, 2010 | Samsung SW62ASP Top Load Washer
    My samsung smart wash b1245S 6kg washes but won't spin, it displays an EU message on digital display, what is wrong ???
    its your drain pump
    must be a common problem on this machine. i have had to change the pump 4 times now in the 4 years i have had it.
    they are about £8 off ebay including the postage
    Apr 14, 2008 | Washing Machines
    Washing Machines Logo
    43 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
