Question about Frigidaire Fra064vu1 Air Conditioner
Frigidaire air conditioner model FRA064VU1 stopped working. Tried reset button on the power cable and still nothing
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 534 Answers
SOURCE: MY 2YEAR OLD WINDOW AIR CONDITIONER WON'T POWER ON
Apparently the gfci on the plug (the reset button) has gone bad. The best thing to do is to purchase a new cord and replace it. These switches sometimes go bad. Good Luck
Dave
Posted on Jul 28, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: my frigidaire air conditioner cord
hello
I would have the cord replaced.The test and reset is a ground fault,or a saftey device.
If its not working correctly then have it replaced
Posted on Aug 30, 2010
  • 251 Answers
SOURCE: MY frigidaire Air Conditioner model
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
Model FAZ12HS2A. When in Heat mode, why does it blow cool air?
Hello J, thanks for your post!
I see that your Frigidaire air conditioner is not emitting the proper air when in heat mode. I would recommend performing a reset on your air conditioner and you can do that by disconnecting the power cord. Once you have removed the power cord, press the reset button and then the test button. You should then be able to plug it back into the wall and start it up. If you continue to have issue with it an electrical component may need to be replaced and I would recommend this be completed by a professional technician. They would have the knowledge on how to properly disassemble the air conditioner without any harm. Good luck! -Matt
Jan 05, 2016 | Frigidaire Heating & Cooling
Where is the button to reset on a frigidaire air conditioner
Hi friend, that's a great question!
To reset your Frigidaire air conditioner you would need to make sure the appliance is turned off and unplugged. On the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in and it should be reset. -Matt
Jul 23, 2014 | Frigidaire Heating & Cooling
My frigidaire air conditioner LRA067AT7 won't cool
The thermostat isn't turning on the compressor. Check it out first. If it seems ok then check the wires going to the compressor. One of the 2 places will be the trouble .
Feb 05, 2014 | Frigidaire 6000 BTU Window Room Air...
Frigidaire FRA064VU1 repair
Hello, yes once you remove the outer housing it should not be difficult to snap or fasten into place.
Jul 06, 2012 | Frigidaire Fra064vu1 Air Conditioner
All of a sudden it stopped working. The display now only blinks STOP. I tried unplugging it, resetting it, pushing the on/off button. Nothing happens, it just keeps flashing STOP. Very frustrating
I had the same problem until i opened the drain and got it nice and clear. Pushed the reset button and now it works, hopefully thats what fixes your problem.
Jul 15, 2011 | Haier CPN10XC9 Air Conditioner
Dave
Jul 28, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Jun 10, 2008 | Frigidaire FAH106N1 Wall/Window Air...
Frigidaire Fra064vu1 Air Conditioner Logo
22 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
