Question about NINJA SEARious Slow Cooker
E 01 code - NINJA SEARious Slow Cooker
Tip
West Bend Crockpot EO1 Error Code
<p>Your crockpot is giving you an <b>error code EO1</b>. Now you need to know how to get the code off of your crockpot so that you can use it. <br /> <p><br /> <br /> <p>First, let me explain what the code means. That code tells you that your <b>temperature sensor</b> did not calibrate correctly. Do not worry, this is usually just a temporary situation and the sensor can be reset through a few very simple steps.<br /> <p><br /> <br /> <p>The first thing to do is to unplug your unit from the electric socket. Leave it unplugged for at least ten seconds.<br /> <p><br /> <br /> <p>Then plug it back into the electrical outlet.<br /> <p><br /> <br /> <p>When you have it plugged back in, hit the <b>POWER</b> button once and then within one second hit the <b>COOK</b> button once.<br /> <p><br /> <br /> <p>Now the appliance should be ready to use.<br /> <p><br /> <br /> <p>If you have the problem again just repeat these steps to clear the error code.<br /> <p><br /> <br /> <p>This is how you can easily <b>fix the EO1 error code.</b><br /> <p><br /> <br />
on Feb 08, 2011 | Crock Pots & Slow Cookers
What does E 4 on display panel mean?????
Hi Noreen,
The "e4" is an error code. You need to search online for "error code e4 + your make". You should then, at least, know what the problem is.
Aug 25, 2015 | Crock Pots & Slow Cookers
Handle to my crockpot broke. The broken piece part number is c33511-01. Where can I get a replacement part?
You can go on line to www,rival.com, or easier , you can look up your local dealer in the phone book white or yellow pages, which I feel to be your best bet. They will be able to order for you what you need or possibly have your part in stock. If your handle has broke so have others. Give it a shot. GOOD LUCK.
Sep 10, 2011 | Rival SCV702 Slow Cooker
E01 code on west bend slow cooker - how can I fix
Your crockpot is giving you an error code EO1. Now you need to know how to get the code off of your crockpot so that you can use it.
Here is a tip that will tell you how to fix the EO1 error code.
West Bend Crockpot EO1 Error Codeheatman101
Jan 14, 2011 | West Bend 84496 6-Quart Slow Cooker
E01 code shows on screen. How do I erase this code if possible
Hold cook button in while plugging-in powercord . You might have to quickly hit the select button. If if doen't work the first time keep trying.
Jan 09, 2010 | West Bend 84396 6-Quart Slow Cooker
Handle on crockpot lid broke off.can I replace it at store where purchased?
I have had the same problem. Spoke to rival customer service and they no longer sell replacement lids for model number SCE502. I've read to take the screw from the knob to a hardware store and then find a knob which will fit it.
Someone else suggested that if the knob is mostly intact, ask hardware store for araldite glue
Dec 08, 2007 | Rival 3755 5.5-Quart
No manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000067744.pdf
Nov 27, 2007 | George Foreman GV5 4-Quart
Displays E 01
Talked to the nice lady at West Bend. Apparently, the problem comes up when the unit is "cold"... whatever that means. She said to plug it in, wait a second, then push the power button, then "cook" immediately. No pause. Don't hold either button. I tried it, it worked on mine.
Apparently, this a feature for some reason.
May 17, 2007 | West Bend 85146 6-Quart
NINJA SEARious Slow Cooker Logo
53 people viewed this question
Top NINJA Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a NINJA Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
