Question about Plumbing
Glacier Bay kitchen faucet with pull down sprayer model #883-432. Hot and cold connections are leaking. When tightened together, home end hits nut on faucet end and cannot be tightened any further. Should there be a washer at the base of the home end? Seems like that would solve it. Tried silicone tape, no go.
3 Suggested Answers
  • 74 Answers
SOURCE: trouble connecting supply lines--leaking/Hansgrohe kitchen faucet
You are probably missing the feral (sp?) that belongs behind the nut on the compression fitting. The feral looks like a coper or plastic ring for your finger that is also slightly coned shaped....http://images.google.com/imgres?imgurl=http://www.plumbingmall.net/catalog/ferrules_thumb.jpg&imgrefurl=http://www.plumbingmall.net/servlet/Categories%3Fcategory%3DPIPING%2BSYSTEMS:PLUMBING:MANABLOC%2BACCESSORIES&usg=__EswgpaP-RUncJqHYNZbLDFsAw0E=&h=77&w=83&sz=2&hl=en&start=3&um=1&tbnid=qzemJ2Zin0P1MM:&tbnh=70&tbnw=75&prev=/images%3Fq%3Dplumbing%2Bferrule%26ndsp%3D18%26hl%3Den%26client%3Dfirefox-a%26rls%3Dcom.ubuntu:en-US:official%26hs%3Dhh9%26sa%3DN%26um%3D1
Posted on Apr 27, 2009
  • 25 Answers
SOURCE: Sprayer hose leaks at the base of the faucet after sprayer replacement and thread tape application
Make sure the internal washer is intact and there is no damage to the parts that you are connecting together. Also, do not use too much tape....one or two winds is enough and wind in in the direction of the action of the female connector (clockwise) so you don't bunch it up in one spot.
Posted on May 05, 2012
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
I have a glaicer bay kitchen faucet and when the water is turned on there is thumping. When I take the sprayer off the thumping stops.... is therea probelm with the sprayer?
to reduce the 'thumping' noise, open the supply valves more. If they are already at maximum, you may have a restriction further up the supply lines. Thumping is typically caused by unbalanced flow around the seat and washer, usually caused by restrictions.
Mar 03, 2014 | Glacier Bay Kitchen Faucets. Lyndhurst...
Wiggling Goose Neck
There could be loose hardware inside at the base of the goose neck. You will have to remove your carefully installed faucet and take a look inside to find out.
Nov 13, 2013 | Globe Union Glacier Bay 8 In Double Handle...
May 05, 2012 | Plumbing
Have just installed glacier bay faucet model #8181/ 785 564 single handle with pull-out sprayer. once pulled out the sprayer will not re-seat into the faucet but hangs out about an inch or two. have...
Take it back to HD or Lowes where you got it and trade it in for a Delta....you will be glad you did... this is only the beginning of your problems....you get what you pay for...
heatman101
Apr 21, 2011 | Microwave Ovens
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Glacier bay kitchen faucets with 2 handles and a sprayer
to be honest with you if there is a problem the glacier bay brand is from home depot and they are usualy around 20 to 30 dollars the replacement stems are usualy 15 to 40 depending on the part plus the hours ur gonna spend fixing it your better off with a full replacement. if replaced keep in mind you might want to replace the supliy lines to the faucet with stainless steal suply lines to ensure no leaks and if your shut offs are old dont touch them shut off your water main and drain down your house by opening all the faucets and shower valvs in your house then drain at the lowest point in the house weather it be a sink in the basement or an out side faucet once the supliy lines and faucet is in place then close all the faucets you opened and slowly turn on the water to your house slowly and this will ensure you dont have any leeks from your shutoffs good luck  your friendly plumber
Apr 12, 2009 | Plumbing
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Plumbing Logo
447 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
