Question about Sony Ericsson T610
Changed service, can't receive a signal
I couldn't get a T-Mobile signal when I moved, so I just switched to AT&T. However, with the new SIM card in, the phone only picks up a signal about 5-10% of the time. The SIM card works great in my wife's Treo, but either SIM card won't work in my t610.
  • 76 Answers
ATT runs off of the 850 mhz bandwith while tmobile uses 900. The old phone you are using uses tmobiles bandwith and only catches 850 occasionaly. I would suggest trying to get an upgraded from ATT when you signed the contract
Posted on Sep 27, 2007
SOURCE:
Phone is locked emergency calls only
Did you mean your new used phone shown Emergency calls only while inserting your metro pcs sim card?
Yes means, There are two possibilities to get this type of issue.
1.You mobile phone receives weak signal from near tower so try to Switch off your mobile,wait few seconds and switch on.
2.Your mobile is locked to particular network provider.
If your problem persists after switch on your phone means definitely your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit http://www.theunlockspot.com/samsung/rs10wp8/ I hope it will be very useful to you.
Sep 11, 2014 | Samsung SGH Cell Phones
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
MY SIM CARD WONT WORK IN MY HTC INSPIRE
switch off your mobile and keep away your sim, insert another working sim in the mobile and turn-on your mobile... if this sim is working, then turn off your mobile and re-insert your old sim. now it will work.
in case mobile is not working with new sim, you have to replace the "signal chip" of your mobile.
Best of Luck!
Pawan Verma
Nov 10, 2011 | HTC Inspire 4G Smartphone
Sir my pfone not show network
As you are not getting network, below are the possible causes for that,
1. Your phone is not receiving any radio signals or the received signal is too weak.
Contact service provider and make sure that the network has a coverage where you are.If so try to do new search.
2. SIM card is not working properly.
Insert your sim in any other mobile. If you still get the same or similar message please contact your network provider.
3. Phone is not working properly
Insert your sim in any other mobile. If it works then the problem is with the mobile only. Please go to the nearest authorized dealer of your mobile make. They will rectify the problem.
Thank You
Aug 17, 2010 | Samsung SGH-J600 Cellular Phone
No network coverage
Phone is not receiving any radio signal / received signal is too weak:
Confirm that network coverage is available where you are by contacting your service provider.
SIM card is not working properly:
Insert your SIM card into another phone
Note: Contact your service provider if you get the same message again.
Phone is not working properly:
Insert your SIM card into another phone. If the second phone works with the inserted SIM card, then
the problem is probably with the first instrument.
Note: In this case, contact your nearest Sony Ericsson service center regarding your phone problem.
May 30, 2010 | Sony Ericsson Walkman® W995 Cell Phone
I have almost no signal and yet other phones on same network have full signal. Can I strenghten the signal?
First ensure that it is not a network related issue by using another sim card (if possible).
Try moving out to an open area for a better signal reception.
If your mobile still receives no signal, the radio transceiver might need to be replaced. If the phone is in warranty take it to the service center for free repairs. If the warranty has expired, you will have to pay for repairs.
I suggest you get a repair estimate and if it is close to a new handset, buy a new one.
Nov 30, 2009 | Samsung S8300 Ultra Touch platinium-red...
Can not receive any signal
it is the problem of pfo so u have to change the pfo go to ur nearest care center
Mar 14, 2009 | Sony Ericsson w580i Cellular Phone
Unlock code
SIM Cards and Unlocking your Phone What is a SIM?
Subscriber Identity Module (SIM): A smart card containing the telephone number of the customer, encoded network identification details such as: Call Forwarding, Caller ID, etc., the PIN, and other user data such as the phone book. T-Mobile customers can move their SIM card from any T-Mobile branded phone to any other T-Mobile branded phone without the need to contact Customer Service to activate the new phone. Your rate plan and phone number will follow your SIM to the new phone.
SIM Error Messages:
  • Invalid SIM: This error means that the SIM you have inserted into your phone is either inactive or is not compatible with our service. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
  • Insert SIM: Your SIM is either not inserted in your phone or is inserted improperly. Please remove and re-insert your SIM card. If you continue to receive this error message, your SIM card or phone may be defective. You may take your phone and SIM to a T-Mobile retail store for further assistance and a free SIM card replacement if necessary. Locate a T-Mobile retail store near you.
  • Unregistered SIM: This error may occur if your SIM card is not fully activated or if the SIM card registered to your account is different than the SIM you have in your phone. For assistance with this issue, please contact Customer Service.
  • SIM Not Ready: This error occurs when you have just powered your phone and is due to the phone not being fully initialized. Please wait a few moments before accessing your phonebook or placing a call.
  • OTA OK: This message is displayed when your phone receives a network update, phonebook download, or an Over-The-Air t-zones or Picture Messaging configuration. NOTE: These messages are free of charge and will not be billed to your account or pulled from any text message bucket.
  • Enter PUK: These errors can occur if you have entered your SIM PIN three times incorrectly. If you receive this error message, please contact Customer Service for a PIN Unblocking Key (PUK) to restore access to your phone.
  • Check card, Card Blocked See Supplier, Blocked, SIM Blocked, or Contact Card/Service Provider: These errors may occur if you have entered your PUK ten times incorrectly. If these errors display your SIM is unusable and you will need to purchase a new SIM card. You may purchase a new SIM card from a T-Mobile retail location. Locate a T-Mobile retail store near you.
SIM PIN:
A SIM PIN can be used to prevent access to your phone. When enabled, your phone will prompt you for the SIM PIN when the phone is powered on. Entering the wrong PIN will prevent you from making or receiving calls. SIM PINs are different from a Security Code that your phone may use to secure other phone functions. Please check your phone’s manual for further security details.
T-Mobile SIM PIN numbers are set to default values before purchase. If you change your SIM PIN, it is recommended that you keep record of the new PIN in a safe location. T-Mobile cannot retrieve a lost or forgotten SIM PINs.
  • SIM PIN1: 1234
  • SIM PIN2: 5678 (Only available on select phones)
SIM Unlock:
T-Mobile branded phones operating on the T-Mobile network may only use T-Mobile SIM cards. To use a T-Mobile branded phone on another wireless carrier's network with a non-T-Mobile SIM card, you must first request a "SIM Unlock" code from T-Mobile. Conversely, if you have a phone from another North American wireless carrier, you may need to request a "SIM Unlock" code from that carrier before being able to use a T-Mobile SIM card on the T-Mobile network.
SIM Unlock Requests:
T-Mobile customers must meet the following eligibility requirements before contacting Customer Service to request your SIM Unlock code.
The following restrictions apply to all account types:
  • T-Mobile can provide SIM Unlock Codes only for handsets sold by T-Mobile USA, with the exception of Danger Sidekick devices. T-Mobile can obtain SIM Unlock Codes for companies acquired by t-Mobile USA (VoiceStream, Aerial, Omnipoint, SOL, Digiph, PCS One, and Powertel).
  • SIM Unlock Codes will only be provided after your account has been active for 90 days. Only one unlock code may be provided per customer every 90 days.
  • No SIM Unlock Codes will be provided within the 14-Day Buyer's Remorse period. Customers who purchase phones in CA California or via Amazon.com are granted a 30-Day Buyer's Remorse Period.
  • SIM Unlock Codes are not always available from the Manufacturer. However, T-Mobile will make a dedicated effort to obtain the SIM Unlock code. Note: Other restrictions may apply depending on account type.
Goodluck
Jan 10, 2008 | T-Mobile Wing™ Smartphone
Unlock
i want use it in egypt
Dec 12, 2007 | T-Mobile Wing™ Smartphone
Sony Ericsson T610 Logo
62 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
