Question about Frigidaire FEQ332E Electric Dryer
I have a Frigidaire washer model FTF530FS3 front loader , my dryer has bit the dust and I am trying to find out if the new Frigidaire dryer that is just slightly deeper, only 1/2" deeper will stack on my existing washer. I have called Frigidaire directly and they basically searched as I have searched and just told me that no you cannot stack them as the newer model is bigger.(only 1/2 " deeper and 1/4" wider. Does anyone know if there is some other way to do this?
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Posted on Nov 16, 2007
the dr
  • 447 Answers
SOURCE: Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Posted on Nov 24, 2007
  • 156 Answers
SOURCE: Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Posted on Mar 06, 2008
SOURCE: Front Loader Frigidaire will not drain model no. LTF530FSO
check to make sure all hoses are not clogged - our washer hose before the pump was clogged due to washing a rug that had deteriorating rubber backing - would not drain until I flushed out the hose that goes from the tub t the pump.
Posted on May 01, 2008
SOURCE: How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Posted on Jun 26, 2008
Dimensions for the Frigidaire Front Load Washer FTF530FS3
For a normal install, the washer is 36" H x 24 3/4" D x 26 3/4" W. If you install the washer under a counter with the top sheet, then it needs 34 5/8" to the bottom of the counter. The dimensions are given in the installation guide available from Frigidaire or Sears Parts Direct. See https://secure.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-Parts/user-manuals/manual-downloads/Model-FTF530FS3/1428/0153200?modelNumber=FTF530FS3&diagramPageId=&documentId= . A direct link to the Installation Guide is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/INSTL/L0709314.pdf . See page 3 with the Rough-In dimensions.
I hope this helps.
Feb 24, 2016 | Frigidaire Washing Machines
I have a Frigidaire front loading washer, model FTF530FS3. The dryer that is stacked on top of it just quit. I have discovered that the new model of the dryer for this type, now called Affinity is slightly...
I would bet the manufacturer has an adapter for just this kind of problem. I did an installation on a stacked unit with a similar situation and there was an offset angle piece that attached the base of the dryer to the top of the washer. The front had a molded plastic piece to allow the dryer to rest on the front of the washer. Hope this helps
Oct 18, 2013 | Frigidaire FEQ332E Electric Dryer
Ftf530fs3 no water
1st check to make sure water is coming through the hose to the washer.2nd check where hose is connected, often there is a plastic shipping stopper preventing it.
Sep 22, 2011 | Frigidaire FTF530FS Front Load Washer
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
Can I reverse the door on my new Frigidaire Affinity front loader?
Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
Sean
Mar 26, 2011 | Frigidaire Affinity ATF7000ES Front Load...
I want to change the door around to match the
Unfortunately, only some model Dryer doors are able to be changed, not the washer doors. You can find out the Model of your dryer and I can let you know if indeed you dryer door swing can be changed or not. The other solution is to stack the set to not have the doors impede loading and unloading if your models have a stacking kit available for them. I hope this helps! Good luck!
Dec 29, 2009 | Frigidaire GLTR1670A Front Load Washer
Door opens on wrong side
I don't think you can on a front loader washer.. on your dryer you can see how they have screw covers for interchanging, but on washer there are none.. sorry.. good luck..
Jan 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEQ332E Electric Dryer Logo
62 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
