Question about Kenmore 23613 Progressive PowerMate Bagged Canister Vacuum
Can't get lid to change bag closed on kenmore progressive canister vac
reddevil6
  • 1673 Answers
SOURCE: Kenmore Progressive Canister w/Hepa Filter
May have a problem with the motor protector or the motor itself. The motor thermo protector will shut the motor off if it senses it getting hot. So it could be bad.
Posted on Apr 15, 2008
SOURCE: No power to head of Kenmore Progressive canister vac
The extension wands are defective and have trouble with their plug connectors on each end. The power head has a reset button on top right but no lights mean no power which means the wand isn't connecting the power to anything.
Sears has a new replacement -- too bad it isn't recalled so you could get it for free ($106.59 + tax + shipping). 2nd sweeper -- same problem.
1st sweeper: I just took needlenose pliers and pulled connectors out a little further (Too bad I can't seem to make the 2nd sweeper work with this easily. It might be one of the connectors or the wiring harness inbetween with a break.) Can't buy the wiring harness for this or connectors, just the wand.
If anyone has a working wand you want to sell me email me at hiwhatsnew@hotmail.com. Thanks!
Posted on Jun 12, 2008
  • 231 Answers
SOURCE: Kenmore 25614/25615 Progressive bagged canister vac won't start
sounds like there was a loose connection or loose wire that came in contact with another wire. check your cord for small burn holes, also could have shorted out in the hose or the wand. If you are comfortable to disassemble the vacuum i can walk you through the troubleshooting process so we can find out what actually went bad. id start with the cord though. let me know if you have any questions or need more assistance
Posted on Jan 04, 2010
Testimonial: "This was helpful and the response time was outstanding. Thank you!"
  • 50 Answers
SOURCE: How do you change the bag in a kenmore progressive
There is a latch just under where the hose enters the main canister section, just behind the handle. Pull back on the latch to open the bag compartment. The bag will pull out of it's plastic holder, then slide the new bag all the way in and close the lid.
Posted on Apr 14, 2010
  • 20 Answers
SOURCE: 25512/ 25513 Progressive Canister Vacuum: HI, we have a kenmore progressive canister vacuum ...
cord bad at male prongs, or fuse near motor blown.
Posted on May 06, 2010
How do you change the bag in a kenmore progressive true hepa canister vacuum?
Apr 14, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Jan 04, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Vac has no suction,hose clear and tried new bags
make sure lid is all the way down, detach hose from canister and drop penny through to make sure is clear..
Nov 27, 2009 | Kenmore 25512/ 25513 Progressive Canister...
How to change filters on a Kenmore canister vacuum
Depending on age there may be one or two filters. A Hepa filter is an exhaust filter generally at the back end of the vac, sometimes at the back top.
For this style filter there will be a small grill with a release tab on it, simply pull the finger tab and the grill should pop off revealing the filter.
There is normally a bag chamber filter behind the dust bag as well. Open the bag chamber below the tool storage and remove the bag.There will be a soft filter sitting behind the bag on most models. If it is a sponge type it can be washed and reinstalled when dry, but if fabric it is disposable.Make sure you have replacement filters in hand before changing as some filters simply pop into a reusable frame, often a red frame. If the material slides out the frame is generally reusable, if glued in , it is likely disposable.
USE only the specified filter and chose the best quality multi ply filter bags for maximum vac performance and efficiency
Sep 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Lid won't close
You might have the vacuum bag in incorrectly. Pull your vacuum bag all the way out, and check the cardboard for arrows (as some bags are cut to go in one way, and one way only). If your vacuum has a cartridge that the vacuum bag goes into, make sure that this is seated completely, securely, and correctly. After you have checked all of this, seat your lid meaning make sure it is going to sit correctly on the housing, then as you are closing the lid, check the latch as it begins to close - making sure that the male and female portions are going to match up. You may have to give it a little pressure, but should not have to put enough pressure to break anything. Good luck.
Jan 21, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Lid will not snap shut over vac bag on kenmore magic clue
You have probably closed it by now :-) but when this happened to us we found that if we opened the tool compartment on the lid, the main lid then closed on the bag with a tiny bit of jiggling around. I don't know why, but this worked.
Nov 30, 2008 | Kenmore Vacuums
Kenmore 23613 Progressive PowerMate Bagged Canister Vacuum Logo
49 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
