Question about Polaroid P3000E Single-Sided Printer
I am pressing print but the printer will not print
HP3500 all colors are printing too light - black is gray, blue is light blue, red is pink, etc. All cartridges are full, no error message on printer
Calibration is a printer function that optimizes print quality. If experiencing any print quality problems, calibrate the printer.
  1. Press (Select) to enter the MENUS .
  2. Press (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press (Select) to select CONFIGURE DEVICE .
  4. Press (Down arrow) to highlight PRINT QUALITY .
  5. Press (Select) to select PRINT QUALITY .
  6. Press (Down arrow) to highlight CALIBRATE NOW .
  7. Press (Select) to select CALIBRATE NOW .
  8. Wait for the printer to calibrate.
that should solve your problem
Aug 12, 2010 | HP Color LaserJet 3500 Printer
Color printing, not so colorful. Even with new cartridges
Your model has some print quality pages built in to help diagnose and solve print problems.
1) Press <Menu>
2) Press <Down> button to highlight "Diagnostics"
3) Press the <checkmark>
4) Press <Down> button to highlight "PQ Troubleshooting"
5) Press <checkmark> to print the pages
If you see print-quality defects on the print-quality-troubleshooting pages, calibrate the printer. To calibrate the printer (optimize print quality):
1) Press <Menu>
2) Press <Down> button to highlight "Configure Device"
3) Press <checkmark>
4) Press <Down> button to highlight "Print Quality"
6) Press <Down> to highlight "Full Calibrate Now"
7) Press <Checkmark>
I hope this helps!
Dec 21, 2009 | HP LaserJet CP3505dn Printer
Can't get my HP LaserJet 4MV to print. It printed yesterday but now it says "Printer not responding. The printer is on and I have checked all cables. Help
Can you perform a test print? Try this:
To print a Test Menu page
Press On Line] to take the printer off line.
2 Press [Menu] repeatedly until TEST MENU appears.
3 Press [Item] repeatedly until PS CONFIG PAGE (or another PS test page)
appears.
4 Press [Enter] to print the page. The page will print in less than one minute.
5 Press [On Line] to place the printer back on line.
Did the printer print? If so, you may have either an nterface or cable problem.
Oct 23, 2009 | Office Equipment & Supplies
How do I print config pages for Lexmark T630, T640, T632, T642, and T650?
1 Make sure the printer is on.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Print Menus, and then press Select to
print the page. The message Printing Menus appears on the
display.
4 Verify that the options you installed are correctly listed under
“Installed Features.”
If an option you installed is not listed, turn the printer off, unplug
the power cord, and reinstall the option. See Step 3: “Install
memory and option cards” on page 30 for more information.
5 Verify the amount of memory installed is correctly listed under
“Printer Information.”
6 Verify that the trays are configured for the sizes and types of
print media you loaded.
or
3 Press Menu until you see Print Net Setup, and then press
Select to print the page.
4 Check the first section on the network setup page and confirm
that Status is “Connected.”
If Status is “Not Connected,” your LAN drop may not be active
or your network cable may be malfunctioning. Consult your
network administrator for a solution. Afterward, print another
network setup page to verify connection to your network.
or
1 Launch the CD.
2 Click Quick Reference.
3 Print the documents.
The same Quick Reference pages are stored in the printer. To print
them:
2 Press Menu until you see Help Menu, and then press Select.
3 When you see Quick Reference, press Select.
Sep 25, 2009 | Lexmark T632 Laser Printer
Printer wont work
CARTRIDGE OUT OVERRIDE
From the main menu on the printer, press "right arrow" to "System Setup", then press "Select" (green button with check mark)
Press "right arrow" to "Print Quality" and press "Select"
Press "right arrow" to "Replace Supplies" and press "Select"
Press "right arrow" to "Override Out" and press "Select"
Press "Select"
If "stop at out" is selected, the printer will stop printing when a cartridge reaches the recommended replacement point. If "Override Out" is selected, the printer will continue printing when a cartridge reaches the recommended replacement point. The factory default settig is "Stop at out".
Apr 30, 2009 | Office Equipment & Supplies
I changed the trasfer kit on my HP Color LaserJet 3500 and now the print is very light. I used and OEM transfer kit and followed the instructions provided by HP. Help
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
1. Press MENU to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
Hope this works for you
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Feb 15, 2008 | OKI MICROLINE ML-395 Matrix Printer
Trouble Printing Pictures
Hi
All you need to do is reset the printer to the factory settings, follow the instructions manual for dell 3000cn steps.
Print the Gradation [ESS] Test Print On the Printer
To print all four 20% toner test prints, perform the following step:
Power off the printer.
Hold down the up and down arrow buttons on the printer and power the printer on.
Press the down arrow button until Test Print appears and press the button.
Press the down arrow until Cyan20% [ESS] appears and press the button.
Press the button. The test print will print.
Press the Cancel button.
Press the down arrow until Magenta20% [ESS] appears and press the button.
Press the down arrow until Yellow20% [ESS] appears and press the button.
Press the down arrow until Black20% [ESS] appears and press the button.
STEP: Clean the contact points on the drum cartridge and the right side of the 3000cn-series / 3100cn printer.
To clean the contact points on the drum cartridge and the right side of the printer, perform the following steps:
Unplug the power cable.
Pull to open the front cover, and then lift to open the top cover.
Raise the lever on the top right side of the drum cartridge
Grasp the drum cartridge by the handle and lift up and out
Using a clean, dry, lint-free cloth, wipe the contact points on the drum cartridge
Clean the right side of the drum cartridge.
Using a clean, dry, lint-free cloth, wipe the contact points on the right side of the printer
Insert the drum cartridge.
Close the top and front covers.
Plug in the power cable.
Power on the printer
This should resolve the issue
Nov 08, 2007 | Dell 3100cn Laser Printer
Diagonal lines on print
Follow these steps.
Print Quality Problems on 3010cn.
Reset the NVRAM On the 3010cn
To reset the NVRAM, perform the following steps:
  1. Press the Menu button.
  2. Press the down%20arrow%203100cn.jpg (down arrow) button on the printer until Configure appears, and then press the right%20arrow%203100cn.jpg (right arrow) button on the printer or return%20arrow%203100cn.jpg (Set) button.
  3. Press down%20arrow%203100cn.jpg on the printer until Maintenance appears, and then press right%20arrow%203100cn.jpg on the printer or return%20arrow%203100cn.jpg.
  4. Press the down%20arrow%203100cn.jpg until Init NVRAM appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  5. Press return%20arrow%203100cn.jpgInitializing and Restart Printer will appear.
  6. Power off the printer and power back on.
To print the Gradation [ESS] test print, perform the following steps:
  1. Power off the printer.
  2. Hold down the up and down arrow buttons on the printer and power the printer on. This will bring up a Customer Mode menu.
  3. Press the down arrow button until Test Print appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow button until Gradation [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. On the LCD, Processing appears and the test page is printed.
  4. Press the down arrow until Cyan20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. The test print will print.
  6. Press the Cancel button.
  7. Press the down arrow until Magenta20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  8. Press the return%20arrow%203100cn.jpg button. The test print will print.
  9. Press the Cancel button.
  10. Press the down arrow until Yellow20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  11. Press the return%20arrow%203100cn.jpg button. The test print will print.
  12. Press the Cancel button.
  13. Press the down arrow until Black20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  14. Press the return%20arrow%203100cn.jpg button. The test print will print.
  15. Press the Cancel button.
  16. Power off the printer and power back on.
Reseat the drum cartridge, perform the following steps:
  2. Unplug the power cable.
  3. Pull to open the front cover and then lift to open the top cover. (Figure 1)
    Figure 1 - Open Front and Top Covers
  4. Raise the lever on the top right side of the drum cartridge. (Figure 2)
    Figure 2 - Raise Lever to Release Drum Cartridge
  5. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
    Figure 3 - Remove Drum Cartridge
  6. Insert the drum cartridge.
  7. Close the top and front covers.
  8. Plug in the power cable.
  9. Power on the printer.
Apr 11, 2007 | Dell 3100cn Laser Printer
Polaroid P3000E Single-Sided Printer Logo
Top Polaroid Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jerry Umali
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
