F70 Invalid Device Specific Number shows up on the Valiant and no hot water. What is the fix please?
I have a bosch YS2433R 'Highflow' hot water system. It has a YPRM34XB controller. The controller constantly flashes the number '99'. My home has no hot water. How do I fix this error on the controller so...
Solution for a code 10 or 99 (for my own reference as much as anything!)
Hit change and the down arrow on the controller for 3 seconds.
Wait for the controller to beep and display 00 before using the down key to display 93.
Hit the On/Off button until 000 is displayed on the screen.
Press change and down simultaneously and the controller should revert to the pre set temperature. Hey presto! Hot water!!!
Nov 01, 2010 | Bosch & Tankless LP Hot Water Heater
Getting code f70 & f71 washer will not run water does not fill or spin
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Jun 06, 2010 | Kenmore 47081 Front Load Washer
My dryer panel is blinking F70 and smells of gas
F70 code is warning you that the exhaust vent airflow is insufficient.
  • Check the exhaust hose in the rear of the machine and make sure it it not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic.
  • If using dryer sheets, rinse the lint filter with hot water to remove filmy residue that can restrict airflow through the filter
  • Inspect the outside vent hood for any blockages.
  • The exhaust system may need cleaning. Cleaning kits are available at most home improvement centers.
May 06, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Ive just had a new valiant 28 pro boiler
the faster the flow the low the temp , the slower the flow the hotter the temp
Feb 06, 2010 | Heating & Cooling
No hot water
hi change over vale is sticking /worn or diaphram split if you can get the bits repair it (a bit fidly) or replace it
Aug 20, 2009 | KDS Valiant 6380iPTD-01 Notebook
NO hot water
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
33
Jul 29, 2009 | KDS Valiant 6380iPTD-01 Notebook
Valliant ECOmax boiler is not giving me any hot water
My Valliant Ecotec Pro Combi Boiler (approx 4 years old) does not start up. The fault code showing is F.22. I would be grateful if you could let me know what the problem is and obv how it can be fixed. Thanks and regards, Joanne Byne
Jul 03, 2009 | KDS Valiant 6380iPTD-01 Notebook
I have a Whirlpool duet electonic gas dryer. It will not turn on. The numbers blink on and then off. When it was running the board is flashing on and off and then turns off. It did show the number F70....
The F70 code is warning you that the exhaust vent airflow is insufficient.
  • The exhaust system may need cleaning. Cleaning kits are available at most home improvement centers and this website: http://www.linteater.com/.
If you need further assistance, let me know
Regards,
reg501
Jul 02, 2008 | Whirlpool Dryers
Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Feb 20, 2008 | Gaggenau ED 220/221 Electric Single Oven
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
