Why does DVD say chargement while loading a disc
Dvd wont play disc root comes up?
When you load the DVD, instead of the content loading, the word "Root" comes up? This means the content is either corrupted, the disc is dirty, or damaged. In other words, the laser is not able to reach and pick up the magnetic information on the disc. Does this happen with another DVD player? Try doing that first. In the meantime, clean the disc. If the disc can't be read by another DVD player, then the disc is at fault. If another DVD player can load the disc with no problem, the original DVD player you used, may have a dirty lens (what the laser shoots out of), or the laser is not moving at all. If this is the case, the DVD player is broken.
Nov 25, 2014 | Office Equipment & Supplies
I load a dvd in the sylvania sdvd 9009 player and it says no disc after loading
If the DVD loads, there should be something on the display that indicates it is being read (maybe a spinning disc icon). If it tries to read, then displays the "no disc" icon it means either that particular DVD can't be read or the drive has failed. If you try another DVD and get the same result, you can be pretty sure the drive has failed
Dec 16, 2012 | Televison & Video
My RDR-GX300 Stopped loading & formatting blank discs
either a dirty optical pickup or a a bad optical pickup in the unit=pretty much has to be one or the other
Apr 07, 2012 | Sony RDR-GX300 DVD Recorder
DVD NOT RECEIVING DVD DISCS
Hello
The loading mechanism has the trouble. The inserted CD or DVD does not engage into the laser assembly unit properly. It may be due some fault with its loading motor or loading belt. Check these.
Mar 02, 2012 | Jamo DMR 60 DVD Player/Receiver
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
Oct 23, 2009 | Televison & Video
Dvd player does not load when a disc is inserted
Check ur DVD for smushes,scratches and cracks?
Oct 19, 2009 | Televison & Video
Disc loading
The laser needs to be replaced or the disc is damaged
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Disc Error message
UNPLUG UNIT AND LEAVE OFF FOR 1 MINUTE. THEN PLUG BACK UP AND RESTART
Mar 17, 2008 | Sony RDR-GX300 DVD Recorder
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
