Question about Pioneer CDJ-1000MKII CD Player
Correct set for mixer and pioneer cdjs mk 2
Hi,I am having a problem with my pioneer cdjs if i have both long faders turned to the same volume and the cross fader turned to say for example channel 1 i can still hear channel 2 through the speakers and vice versa I have tried this with 2 mixers and both times it has the same results please can you help me i think i may have wired somethiong up wrong can you please help me with this kind regards Damian Byrne
Try turning you 'Crossfader Switch' from "OFF" to "ON"
Posted on Sep 27, 2007
Volume control of system output is not stable with sudden high volume output bursts. Any ideas?
Sounds like a faulty / worn fader. If it does it on all channels then look at the master fader 1st.
A good source of parts is available here :-
Jul 01, 2010 | Pioneer DJM-600 Silver Professional DJ...
Try looking in the manual - page 18.
Jun 09, 2009 | Pioneer DJm500 Professional DJ Mixer...
DJM 400 Keep going into over on the channel and the master volume
To keep your levels down keep the TRIM don which is the gray knob. Also keep the hi, mid, and low knobs at the medium level. The control cables are for using the fader start function.
Jun 02, 2009 | Pioneer DJm 400 Professional DJ Mixer
What do i need in a mixer? i want to connect my kaoss pad mini, and kaossilator, and obviously a couple of cdjs, and where do i connect them straight in the mixer or amp, im awaiting my purchase and just...
For dj use, industry standard would be something like a Pioneer DJM600 mixer. 4 channels w/ effects and a mic input. To use kaoss it's best to go into Send/Return input through the effects. By tapping on Send, all sound is sent out to the kaoss pad, and comes back into the mixer into the Return inputs. By doing this you can have the kaoss pad on sitting next to the mixer ready to apply effects all the time. Then connect the master outputs from mixer into your amp, or straight to powered speakers. Kaossilator is more of an instrument than effects unit, so plug in to channel 3 after your 2 cdjs in channel 1 and 2. You still have a spare channel left. I use 2 x 1200s and 2 x cdjs with kaoss pad through effects channel in this way. A 4 channel mixer is plenty.
Mar 25, 2009 | Korg Mini Kp Kaoss Pad
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Feb 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
OK, you need to do the following to turn off your Webcam Mic.
1. Right Click On Volume Icon in System Tray
2. Click Open Volume Control
3. Click On Options When The Mixer Appears.
4. Select Properties
5. Adjust The Volume For Recording
6. Then Just Look For The Mic Channel on the Mixer & Set it to Mute or if ut's not available, turn the Volume Fader for the Mic Right Down,
Should Have Something Like The Below Settings
Dec 12, 2008 | Microsoft LifeCam VX-3000 Web Camera
Pioneer DJM-600 Bad feedback when i turn up the master volume
It's not your ground wire with the issue, but your RCA cables. Try disconnecting both turntables, and connect 1 at a time, and do the same test, this way you can isolate the problem. Once you've isolated the problem, then you'll need to have the RCA cables replaced on your turntable.
You might also want to check the Cartridges as well. Sometimes a bad cartridge or headshell connection will cause this issue. Worst case scenario, its your tonearm, but that should be test last.
Also, on the rear of your mixer, there is a gain volume pot, make sure this is not maxed out. Keep it about 3/4 of they up. Again, this is on the rear of your mixer where you connect everything.
Dec 04, 2008 | Pioneer DJM-600 Silver Professional DJ...
Cdj 700
error E-9101 is notifying that there is dust in the system
get the drives professionally cleaned and reset the units
Nov 20, 2007 | Pioneer CDJ-700S Turntable
Pioneer CDJ-1000MKII CD Player Logo
181 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
