tack battery cable loose from battery for 5 minits then put battery cable back on battery and restart tye the trunk shut with a rope to take it to mechanic friend to check lock
You might have installed too many applications! You can do 2 things
Remove the card and restart the mobile (If it works delete the folders from the card)
Hard Format the mobile. (You will loose all your contact, SMS & all the data on mobile in doing so) For that proceed as follow;
1= power off then press 3 keys same time for 10 sec only (volume up+volume down+power)
2= 2 options will appear (Recovery mode/Factory mode)
3=Press volume up for Recovery mode
4=From next select factory reset (use 2nd touch button from left side )
5= next use volume keys for reset data and reboot.
This is mobile why we always having a problems but i want to tell you this about your virus ok , so miss/ sir / madam / i want to tell you one thing you most find out first where is setting in your mobile after that go in phone setting and after that you have to find last down phone restore click to there and phone will ask you do you really want to restore ? you have to say yes then put your phone password and wait until your phone not restart automatically
to restore
1. go in setting
2. find out where is phone restore
3. check in last to enter sitting may be there
4. if not then go in phone setting
5 check in phone setting
6. this is the word may be written there 1. phone restore 2. orginal setting 3. factory restore
7. if you got any one of this then click to this
8 phone will ask you do you really want to restore ?
9. you have to say yes, you see blank area you have to put your phone password
10. after this you have to wait until phone will auto restart
Please backup the data by logging in to Safe Mode, please restart and start pressing F8 key to select Safe Mode then re-install the Windows 7 Operating System using the Recovery Disc or recovery Partition of the Hard Drive. The Recovery Partition can be accessed by restarting the computer and try pressing F10 Key. The Windows XP Operating System is displaying an error because it does not have SATA Driver to detect the Hard Drive. As Windows 7 has it, you can re-install it from recovery partition.
If your system hangs up, instead of re-starting it hit Ctrl-Alt-Delete and then click on End Program. As far as your Desktop Board go to www.microsoft.com and type in Hardware Compatibility List. There will be a listing of the hardware that is compatible with Windows XP. It may not be compatible that is why it is hanging up.
Don't forget to vote on this solution before you log out.
Sometime this happens when you use the drivers on XP you may need to
down load the correct drivers and a good place to start is
driverguide.com you may need to enter details for free registration
Sometime this happens when you use the drivers on XP you may need to down load the correct drivers and a good place to start is driverguide.com you may need to enter details for free registration
hello 1_ can you save your formation in other phone 2_that code format your phone for Nokia only 3_ *#7780# and if you know your scurity nember use it if not use 12345 4_ other nember *#7370# and the security n ...... and look because after this you have like a new mobile
