Netgear n300
How do i open up the ports to play nba2k14 online because the game kicks me out because my ports are not open on the router for this perticular game please help
    Master:
  • 359 Answers
You will have to login to your router and configure it. Usually by default router IP addresses are either 192.168.1.1 or 192.168.0.1. You can type that address into your browser and if you successfully connect you should see a login screen where it asks for user and password. The deafult user and password are usually "admin" and "admin" or user: "admin" with no password.
Posted on Oct 19, 2013
One Piece
  • 53 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Posted on Apr 03, 2008
marked
  • 6487 Answers
SOURCE: Weak connection with my xbox 360
The best way to make the wireless connection stable is to do some changes on the wireless settings of the router , like changing its wireless channel to the highest one to avoid any interference on your area.........
Posted on Nov 05, 2008
  • 132 Answers
SOURCE: router will not allow me to play onling games through xbox 360
If the problem has something to do with NAT firewall in your router, then you may need to open certain application ports for your XBOX in the router. You may check this link from Microsoft http://support.microsoft.com/kb/908874 that talks about NAT firewall and XBOX live.
Hope this helps!
Posted on Nov 09, 2008
Jubert
  • 249 Answers
SOURCE: Can't Open Ports in my Router
Make sure that you set or assign a static IP to your playstation first through your dlink. This would ensure that your playstation would have its own ip address and wont change each time you restart your playstation. Once you have that fixed then you could use the virtual server and set it to open all ports for your playstation's ip address. If it still did not work then instead of using virtual server, try setting your Playstation as a demilitarized zone. If that still did not work I think it would be best to contact your ISP.
Posted on Jun 01, 2009
redhaze89
  • 854 Answers
SOURCE: Can't play Starcraft...
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Jun 23, 2009
Netgear router DN2200/wireless problems.
that really shouldn't hurt it unless it included a pretty nasty fall as he tripped over the cord.
are you certain it still has the correct power cord? i've seen people accidently switch the modem power cord and the router power cord and the router tends to not like that.
good luck
Mar 15, 2013 | NetGear DGN2200 Refurbished WirelessN N300...
Netgear DGN2200 wireless issues
Check the DC supply from AC supply or try to replace the AC DC power your Netgear
Sep 17, 2017 | NetGear DGN2200 Refurbished WirelessN N300...
When i play my x box 360 online it laggs really bad
If you go into your router there should be a listing on the left side that says port forwarding. It lists the ports most commonly used for gaming.
May 27, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I have a netgear wgr614 router and can't get my ps3 to play online.(upnp is not available)
Most routers have a menu you can access.
There you must forward your ports.
You must find out what ports ps3 uses and put them into your gaming ports.
Depending on your router settings you may need to do specific assignments.
This should get you going.
Xbox requires me to have the proper internet settings to access my router.
Portforward.com helps noobs to forward ports on your router by use of your computer. Once they are open, your UPnp will be set.
It may seem hard, but once you give it a shot, you will be happy.
Mar 16, 2010 | NetGear WGR614 Router
GTA IV multiplayer issues
Yes, you have to search for the TCP and UDP port numbers and open them in the router config not forgeting to bind them to your LAN ip address.
Feb 01, 2010 | Gateway Computers & Internet
We used a Netgear wireless router to broadcast signal to our PS3. NEVER had a problem playing ps3 online games. We just got a new apartment and cable internet with ATT. Now, when we try to play online ps3...
Yea the encryption codes can be an issue, but something elts you should check are the other devices you use on the network. Check the port settings and if possible (depending on your model of router you can create a dedicated port for the ps3. If another device tries to use the same port there will be conflicts, and another thing to think about is if you have a n-b-g capable router, devices using b and g will slow the speed of the routers send and recieve capabilities for ALL devices on the network, this can create lagg and boot you off from time to time.
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Im tryin 2 hook up my ps3 to this netgear router isnt connecting
Playing Online Games Behind The Router
A router uses a combination of hardware and software to prevent unauthorized users or internet traffic from accessing your private local area network (LAN). If your game console, such as Playstation is behind the router, you will need to configure routers Port Forwarding feature in order to play online games.
Note: You will need to get the ports and service type for your games. This is usually available from the games website.
Steps how to configure router to play online games:
  1. Open a browser and type in the following URL: http://www.routerlogin.com or http://192.168.1.1 (depending on the model number of the router)
  2. Type the Username as admin and the Password as password and click OK.
  3. Click on Port Forwarding under Advanced menu.
  4. Then click on Add Custom Service
5. Under Service Name, type the name of the game.
  • Select the Service Type from the drop down menu (depending on the game).
  • Type the Starting Port and Ending Port numbers (depending on the game).
  • Type the IP address of your PlayStation in the Server IP Address box and click Apply.
  • Click on WAN Setup under ADVANCED menu.
    • Check the Disable SPI firewall box
    • Change MTU size from 1500 (which is the default) to 1300 and click Apply.
    Now the Playstation is ready to use.
    I hope this helps...
    Apr 10, 2009 | NetGear WGR614 Wireless Router
    Computers & Internet Logo
    29 people viewed this question
    David Payne
    David Payne
