Question about Refrigerators
Westinghouse fridge re391q-r - Refrigerators
Hi i have a Westinghouse side by side fridge freezer WSE6970SA there is no water at the dispenser . how do you remove the front panel from the water dispenser to remove it ?
https://www.bing.com/videos/search?q=replacing+water+switch+on+westinghouse+fridge+door&qpvt=replacing+water+switch+on+estinghouse+fridge+door&FORM=VDRE
Apr 19, 2017 | Westinghouse Refrigerators
New Westinghouse fridge cannot seem to adjust freezer lower than 0' except if power freeze on getting colder ?
read the user manual or get a technician out under warranty
from 10 down to 0 on a fridge is getting colder with the smaller numbers
with a freezer 0 to 10 gets colder as the numbers get bigger
Jun 05, 2016 | Westinghouse Refrigerators
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
Westinghouse fridge freezer fridge not working
What is the model number?
Do you see any ice buildup on the back wall of the freezer or behind it?
Oct 20, 2012 | Westinghouse Refrigerators
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
Westinghouse RJ442 fridge was working now tripping
Is it a GFI that it is tripping. If it is using an extension cord try plugging into a non GFI outlet.
Feb 03, 2010 | Westinghouse Refrigerators
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
