Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
Part/parts of my 17 gallon husky air compressor was stolen. I need to view a manual so I can name the part/parts that were stolen. I've lost my manual.
  • 234 Answers
SOURCE: 6 gallon Husky air compressor won't start
There are a few things that may have happened.
  1. Motor overheated and thermal cutoff switch was tripped. Usually this is a red button on the back of the motor. Press it and it may solve the problem
  2. Motor did not start fast enough and it burned out your starting capacitor. This us usually located on the top of the motor under a dome shaped cover. If replacing these you must match up the mfd rating of the original and the replacement capacitor(s)
Air compressors have a fairly high draw and you should be sure that it has a proper electrical supply to it. Too small of a cord can cause the two above problems.
Also make sure that your pump is not seizing up.
Posted on Apr 15, 2009
gaz-dee
  • 62 Answers
SOURCE: My husky 2 gallon air compressor is not building
sounds like the compression rings on the piston neen replacing or the none return valve faulty.
Posted on Oct 28, 2009
ollie reece
  • 1167 Answers
SOURCE: Husky Air Compressor has rattlling noise!
buddy im an engineer on these machines for 30 years and when this problem has occured believe it or not but it cheaper to buy another pump unit or compressor plus its the hardest job getting the crank out so your choice bud
Posted on Nov 16, 2009
  • 4088 Answers
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
Posted on Jan 18, 2010
  • 15 Answers
SOURCE: husky 26 gallon air compressor runs but will not
replace the valve plate
Posted on Mar 19, 2010
CAN YOU STAND THE Husky WL651004AJ UPRIGHT?
Your compressor will work in the vertical position however you will not be able to properly drain the water from the tank in this position.
Feb 18, 2012 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky Manual for TF291201AJ
Go to http://www.chpower.com/manualsearch/ (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
Oct 16, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My 1.7 26 gallon husky upright will not come on at all
Did you trip the reset button? It should be there someplace i a spot where you can't see it, just push it till it clicks, make sure the switch is on. Hope this helps.
Jul 04, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Need to find out how to replace belt on WL65 cambell hausfeld air compressor
Not sure how easy it will be to locate repair instructions if they are not in your manual. However maybe the diagram of the pump is all you need. Just click on the first link below. It will open up the pump diagram. #14 is the belt.
I also included the link to the site where you can get a look a at the parts list and order parts for your compressor.
Hope something here helps.
If not please let me know and I'll try and describe the proccess for the belt remove to you.
Pump diagram:
http://www.mastertoolrepair.com/images/WL390100-Pump.jpg
Compressor diagram and parts list:
http://www.mastertoolrepair.com/wl650003-wl650102-wl650102aj-wl650202-wl650601-p-28707.html
Pump parts list:
http://www.mastertoolrepair.com/wl390100-p-17694.html
Nov 19, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Nov 16, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I need a new belt for my Husky air compressor but I don't know
This is a simple way to replace your belt without the old one for comparison. Use a piece of rope thick enough to fit inside the pulley, (cloths line works well). Simple wind it around the pulleys marking where the two ends meet. Cut and measure it. Take the piece of rope and measurement to a auto parts store and ask them to match it up. An automotive belt will work fine.
If this is a flat belt they should still be able to help you.
Aug 07, 2009 | Air Tools & Compressors
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
23 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
