Question about Samsung Digimax S630 Digital Camera
Memory card First usage - and have problems with formatting a memory card. When go to Menu, Format and choose Yes option, always turns me to option No and shows message Card error, although I tried to move protection button up and down on the card.
  • 91 Answers
Is it for a camera or a phone because if it is for a camera you have to format the memory card by the camera itself you cannot format the data or etc on the computer
Posted on Sep 27, 2007
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
How do I format the sd card in the DMC_ZS7
Welcome to FixYa.
To format the SD card, select [Format] from the [Setup] menu
To bring up the Menu option, press the Menu/Set button. Then select [Setup] and then select [FORMAT]. Then choose Yes to format the card.
Please note:
This requires a sufficiently charged battery, or an AC adaptor (optional) and DC coupler (optional). When
formatting the built-in memory, remove the cards.
(Only inserted card will be formatted if present; built-in memory will be formatted if no card is inserted.)
• Always format cards with this camera.
• All picture data including protected pictures will be deleted.
• Do not turn off power or perform other operations during formatting.
Thanks for using FixYa.
Feb 11, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
Fuji FinePix S2 Pro New 4 Gb disk in cam prompts msg ''Card not initialzied.'' Have tried many things. None work. Help.
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Jun 25, 2010 | Fuji FinePix S2 Pro Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
The digital card should hold 32 pictures but is only holding 7. It has always taken the full 32 pictures in the past.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok.
Jun 18, 2009 | Olympus Stylus 710 Digital Camera
I am facing "write protected" message on my camera display
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect error message and the card can be used again.
Jan 04, 2009 | Olympus Camedia C-720 Ultra Zoom Digital...
In...Memory Full Problem
Try to format the memory. Go to the menu to setup option and press ok. Go to memory format and press ok. You will see format yes or no. Choose Yes and press ok. This will permanently erase all images from the memory and will solve the issue of the camera always reading memory full.
Dec 16, 2008 | Olympus SP-510 UZ Digital Camera
Have a stylus 410 when i turn the camera on it displays 'write protect'?
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Sep 23, 2008 | Olympus Cameras
Memory card
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect image and the card can be used again.
Sep 05, 2008 | Olympus C-315 Zoom Digital Camera
When i turn my digital camera on with the memory card in it (XD M256mb) it says the card is full. I go to erase photos and it says there are no photos to erase. If i take the memory card out, i can take 15...
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card full message and the card can be used again.
Jul 20, 2008 | Olympus Cameras
Samsung Digimax S630 Digital Camera Logo
82 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
