Question about ZTE Lcd Screen Display Ecran Pane For Blade N880 U880 V880 V800 Fpc: Ams353fd09
ZTE-U V800 - ZTE Lcd Screen Display Ecran Pane For Blade N880 U880 V880 V800 Fpc: Ams353fd09
Check sd card
The V800 works with SD cards. Your new 16GB card is a SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to go with SD cards, 2GB and smaller.
Feb 23, 2012 | Samsung Digimax V800 Digital Camera
Samsung Digimax as a webcam??
I know this isn't the answer you wanted to see, but no. The V800 was designed as a camera, storing images (and videos) to a memory card, not to stream them live to another device.
Jun 06, 2010 | Samsung Digimax V800 Digital Camera
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
Is the digimax v800 compatible with windows 7?
Set your windows 7 machine to run in windows XP mode.
Jan 18, 2010 | Samsung Digimax V800 Digital Camera
SAMSUNG V800 SDHC CARD FIRMWARE UPGRADE
No. The differences between SD and SDHC goes beyond what firmware can change. It's possible to design a device to use both SD and SDHC cards, but a device that was only designed for SD cards cannot use SDHC cards without hardware changes.
Feb 05, 2009 | Samsung Digimax V800 Digital Camera
V800;bad!!!
try buying a new battry then charge it for sumthin lyk 16 hours
Apr 17, 2008 | Sony Ericsson V800
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
redrivera0314@yahoo.com
Feb 04, 2008 | Yamaha RX-V800 Receiver
Unlocking Sony Ericsson V800 - 8 Digit Pin
Depending on where you brought the phone from, it have a service provider lock on it. So the best option is to go back to the seller where you bought it from and find that out first. That would be the only problem. Once that has been confirmed you can get the unlock codes so you can open up the network connections to see other networks or it would be hopeless.
Dec 13, 2007 | Sony Ericsson V800
Problem in yamaha rx v800
Hello!!! Are you electronic technician? You should see the transistors Q22A, Q22C, Q19C e Q19A and its drivers on Main Board. All the best, Rasgador
Aug 03, 2007 | Yamaha RX-V800 Receiver
ZTE Lcd Screen Display Ecran Pane For Blade N880 U880 V880 V800 Fpc: Ams353fd09 Logo
20 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
