Robertshaw 7000 astr-4 pilot light wont stay lite
SOURCE: gas firelog pilot light will not stay lite
try to replace the thermo couple
Posted on Nov 25, 2008
arealplumber
  • 33 Answers
SOURCE: pilot lite will not stay lite
You need to change the thermocouple on the unit.
First check to see if the flame is hitting the thermocouple when the flame is on when you hold down the button. If it is then remove the the thermocouple and replace with the same size. You should be able to pick one up at your local hardware store.
If when you replace the thermocouple the flame does not stay lit still you may have a bad gas valve.
Hope this helps and please rate this!
Posted on Dec 08, 2008
SOURCE: laars lite 2 pool heater burner not lite
ive got the same problem and am fitting a new thermal generator i will let you know if it works
Posted on Feb 28, 2009
  • 3309 Answers
SOURCE: my pilot light wont stay lit
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Posted on Feb 08, 2010
SOURCE: Forsaire by Williams Model 455 FEI, will spark but does not light
i had this problem a couple years ago and I had to scape where the flame lights and reset at the fuse box and it worked good luck
Posted on Feb 21, 2010
Why won't my Robertshaw gas furnace pilot light stay lit..Do I need a therm couplen or What.
if gas line to pilot generator clean and sill wont stay lit need new pilot generator
Jan 10, 2016 | Robertshaw 720-007 universal gas valve for...
The pilot lite will light but the main burners wont The high temp light came on but the grease wasn't over temp. I discounted high temp senisor light is still on what do I do now
Most likely the high limit is defective. This can shut down both the pilot and main burners. You can try jumping the high temp sensor leads to see if this solves the problem, assuming it is a standard Robertshaw high limit. Do this only to test, however. Bypassing the high limit can be very dangerous if the thermostat is defective or the oil level is below the sensor bulb. If your high limit has more than two wires, you may need a wiring diagram to determine which leads to jump.
Dec 15, 2014 | Vulcan Kitchen Appliances - Others
Jandy lite 2 pilot wont light
dirty pilot tubing or weak pilot generator
Dec 04, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
Robertshaw 7200 series gas valve manual
have a robertshaw 7200 ercs gas valve, 1 year old, pilot wont light... any advise anyone know pilot lighting instructions ?
Nov 01, 2010 | Heating & Cooling
I have a raypak heater with robertshaw 7000 gas
Remove the wires from the gas valve and call for it to light. While it is trying to light, take a voltage reading on the wires that go to the valve. If it is sending voltage to the valve and it won't energize the valve then the valve is defective. Just make sure that the valve is being told to come on. It could just be a limit switch. Double check the manual reset limits also before doing the vavle check. Hope this helps.
Mar 21, 2009 | Water Heaters
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
