My sidekick lx trackball won't work
More than likely, the trackball on your Side LX is really dirty. Overtime, dirt and grime gets in between the ball and the sensors.
It is really easy to clean it, you will need q-tips and IPA alcohol.
Check out the Video at the following link to see how the trackball cleaning on the Sidekick LX is done
Clean the Trackball on a Sidekick LX
SOURCE: my phone fell into a pool then only the trackball
im so sorry for this inconvienience, f you didnt automatically remove the battery after dropping it in the pool then you are almost surely out of luck. leaving the battery out is key, after that take it to an electronics repair store and have them to dry it out and spray electrical parts cleaner on it! this helps it evaporate water and prevent oxidation (which is conductive) after they have finished your phone could work for the next two years!
SOURCE: whats wrong with my sidekick lx trackball
SOURCE: sidekick trackball won't work =[
More than likely, the trackball on your Sidekick is really dirty. Overtime, dirt and grime gets in between the ball and the sensors.
It is really easy to clean it, you will need q-tips and IPA alcohol. No dis assembly is usually needed!
Check out the Video at the following link to see how the trackball cleaning on the Sidekick is done
Sidekick Trackball Cleaning Guide
charging
