Question about Garden
17.5 B&S model 313707
Starts low rpm then shuts off
Model # 313707 systematic
You can find the full schematic and parts list for model model 313707. This link has everything on your machine. A full set of schematics and a full parts list for every part.
Briggs and Stratton 313707 0162 E5 Engine Parts
Jun 05, 2014 | MTD Yard Machines Yad achine 42" 420cc MTD...
My explorer is running at very low RPM when I start it and will sometimes shut off
The throttle positioning sensor is bad and needs replaced. My 1995 F250 did the same thing and runs fine now the sensor has been replaced.
Jan 13, 2013 | 1999 Ford Explorer
Torque pattern for Briggs & Stratton 313707 OHV head bolts
its a criss cross patern dont over tight they will break off when running make sure of your tork on them
Jan 03, 2013 | Briggs & Stratton Briggs Stratton...
P0171
PO171--System too Lean (Bank 1)
Oxygen Sensor Codes
The possible failed O2 sensor is not causing
your shutting off & other issues
Go to Repair Shop & have them road test
Go with them & explain things,don't just leave
it,they won't do anything
Dec 02, 2012 | 2000 Hyundai Sonata
1999 chrysler sebring low oil pressure at idle
It may be the oil pump. If the gauge is going up when the rpms increase it's probably not the gauge or pressure switch. If the computer senses the oil pressure is low it will shut the vehicle off to try to save it's self from catastrophic failure. Also it may start cranking longer before starting. Thats it building oil pressure before the computer will let it start. Make sure oil is full, clean & thick.
Nov 05, 2012 | 1999 Chrysler Sebring
Faulty oil pressure sensor
I would scan the system for fault codes.
Jun 15, 2017 | 2002 Isuzu Trooper
I disconected the battery for awhile to replace the ground cable when i hooked the battery back up it seems the idle is off and it is now stalling at low rpms
Computer needs to re-learn. it will take a few cycles before it goes back to normal operation. Drive it around, up & down hills, hi & low rpm & speeds, shut it down for a bit and start over again. Let the car cool down a bit before repeating. In the future, if u have to remove a battery cable, make or buy a gadget that connects a 9v battery to your cigarette lighter to hold onto the info...
Jan 10, 2011 | 1990 BMW 5 Series
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
