Question about Drills
Makita uml15 user guide - Drills
Makita 10" dual slide compound miter saw jerky while moving in and out. What,s wrong?
The pillow block bearing, guide bushings, or even the slide lock mechanism could be the culprit.
If you post the model number I can help narrow it down for you.
Feb 15, 2017 | Makita Saws
Reverse position of Makita?
Right above the switch there is a small lever. That's the reverse switch. You can find on page 5 of user manual
http://www.makita.ca/data/upload/owners_manuals/FS2200%20-%20EN,FR,SP_owner_English.pdf
Regards, Juraj
Mar 12, 2014 | Makita Drills: 2,500 RPM 1/4 in. Drywall...
The battery is fine and the guide light comes on fine, but mt Makita BHP451 has no power to the motor. What's the problem?
switch it between forward and reverse a few times without pulling the trigger. then try again.
Nov 06, 2013 | Makita Drills
Makita template guide does not fit
My Makita router arrived with a couple of template guide bushes of different sizes. The size of guide bush chosen for use with a particular template will be dictated by the template - stock templates usually state the size of guide to be used with that template and mostly these are generally so common sizes a good router is supplied with them, from memory I think the smaller of my guides is something like 17 mm.
Template guide bushes are flimsy and easily damaged and so it is expected router users will be buying spares and other sizes. They are almost universal but not quite and router users are quite adept at minor modifications to make things fit, and not just guide bushes but also router tables, adaptors for various tasks and so forth.
I suggest you take a glance through a few catalogues featuring router accessories, including Makita of course.
May 06, 2017 | Makita Tools & Hardware - Others
I just acquired an LS1011 Makita saw. How does
unscrew the handle in the front to change, also I would recommend going to Makitatools.com and typing on your model number to download a users manual for this tool, it would be helpful to get the most out of it.
Oct 25, 2009 | Makita 10" Miter Saw LS1030N
Makita Circular saw 5007NB, the cutting depth guide is jammed. What can I do?
you can try spraying some lubricant on the bolt/roll pin and see if that frees it up that is about all i used to do to them
Jul 01, 2009 | Makita 7 1/4" Circular Saw 5007NB
Drills Logo
170 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
