Question about Midland Radio Communications
No sound through the speaker. when you try to key it up, sound comes out of the hand microphone
    Novelist:
  • Midland Expert
  • 500 Answers
Try a different microphone. Could have a broken /frayed wire touching on the inside at the mic plug. or it could be plugged in the wrong way. I have seen mic plugs turned upside down and forced into the socket. if this doesn't solve your problem with a different mic. problem may lie in the radio. if its a small chasis radio there are small vertical boards that get loose. these can cause issues too. you can wiggle or press on the boards and everything works again. they just need to be re=soldered. some are very small you may want to take to someone to solder .
Posted on Oct 21, 2013
Headphone problem
Ensure you are not plugging into the microphone input.
Dec 17, 2015 | Computers & Internet
Humming sound when I record
Sounds like it might be feedback from another source or perhaps a loose connection. Try moving the microphone away from power sources or anything that might cause feedback, such as speakers etc.
Apr 24, 2012 | Samson Meteor Mic - USB Microphone
Installed USB microphone, but NO sound.
select the device from control panel /sound and audio device / audio .../sound recording ...
if it doesnt work ...look for the device ( microphone ) on volume panel ( double click the speaker from the system tray ) if you do not see a volume for mic...click options..and check the microphone from there ...after that look out and be sure it s not muted...it has to work if it is proper installed..
May 28, 2009 | Micro Electronics PowerSpec 8250 PC...
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
No sound from headset
MUTE THE SPAKER SOUND AND ADJUST THE SOUND SETTING FOR HEADSET
Jan 26, 2009 | Audio Players & Recorders
Microphone hissing sound
That sounds alot like the microphone booster in control panel. Depending on what version of windows your are using, you can just open the sound control from the taskbar and go to the advanced settings and uncheck the setting "microphone booster". Adjust microhpone volume accordingly.
Dec 31, 2008 | Yamaha WaveForce 192XG Sound Card
No sound from in-built microphone and sound through headphones
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Nov 28, 2008 | Computers & Internet
Microphone and speaker problems
Do a virus scan first FREE ANTI VIRUS Try here its free http://www.kaspersky.com/kos/eng/partner... If you can not access or open IE right click in and select Properties then set the homepage to Blank! SOUND RECORDING\MIC ON USB CAMERA In Windows XP Select the proper Audio Input Device (Sound Recording) under the Audio Tab in Sounds and Audio Devices in Control panel. Usually it is name after the USB Camera. CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester.
Sep 20, 2007 | Audio Players & Recorders
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Mar 07, 2007 | Maxon SP-100G (4 Channels) 2-Way Radio
Laptop sound
It sounds as if you have got your inbuilt microphone active and it is amplifying the sound coming from your speakers, try muting the microphone off through your sound or speaker icon normally on your task bar on right hand side, this happened to me when i first installed a web cam and set up the microphone volume. Hope this helps, other than re installing sound card drivers.
Oct 08, 2006 | Acer Aspire 1642ZWLMi Notebook
Radio Communications Logo
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
