Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite model 970 c41072 00 drum
What is the drum capacity on this model?
Jimster
  • 240 Answers
SOURCE: What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
Posted on Jun 01, 2008
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Posted on Aug 30, 2008
  • 8 Answers
SOURCE: will not pump Kenmore model 970-c45072-00, purchased in 2005
Pump blocked probably something stopping it, sock, coin etc
Posted on Mar 13, 2009
  • 7 Answers
SOURCE: Hi There. My Kenmore
You might want to check the plumbing in the bottom of the machine for clogs. On most modern washers, the spin cycle will not start if the water is not completely drained or doesn't drain fast enough. I had a similar problem and found a there was a rubber fitting with a plastic cup inside that serves as a trap to prevent debris from entering the pump. It had a piece of scotchbrite, forty cents worth of change and a hairpin stuck in it.
Posted on Jan 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: What capacity is a Kenmore Elite, king size, heavy
3.8 cu ft
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
My kenmore 970-38712 washer makes a terriible banging noise on the final spin.
http://www.searspartsdirect.com/model-number/9703871220/0582/0153200.html?searchType=modelSearch&q=970-38712&searchTerm=970-38712
This link shows you your tub parts. There are 2 springs and 2 shock absorbers. Those may be bad broken or loose and one other thing to check is make sure the inside drum has not broken off of the spider assembly in the back. An easy way to check that is open the door and grab the front lip of the metal tub and try to move it up and down, you will notice a huge amount of movement if it is broken loose. The videos I posted apply to all front load washers, The first 2 are great on diagnosing and the last one shows whats left of a broken spider gear. Kenmore Washing Machine Model 970 3871220 9703871220 970 3871220 Parts
If it is the spider support assembly then you will have to replace the entire inner tub and that is about $400 just in parts.
Jan 14, 2017 | Kenmore Washing Machines
Model 10.87729701
If the dryer comes on and sounds like the motor is running, your most likely failure would be a broken belt. This is replaced by removing the top first, then the toe kick, and the front door and panel. Pleazer Appliance...
Apr 07, 2014 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric Dryer......Starts, runs and drys but has a REALLY loud squeaking sound
Your drum rollers is in need of lubrication.
You can lube them with a high quality machine oil like 3inOne oil.
Please rate me
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite range, model 970-698593, Error Code E015
Just asking if your model number is correct. I do not find 970 models but do find 790 models. If it is a 790 model there can be aproblem with the door lock on the oven door. You may want to check to see if all the shipping materials have been removed from the door lock / latching area. I would recommend that you review the installation instructions in the owners manual, paying particular attention to the removal of shipping materials.
Adittionally if the problem presists it says to replace the Electronic Range Control (ERC) This is not a cheap part! Good thing it will be at their expense including the repair service call..
Hopefully you have already called for warranty service? We both know a brand new oven should not be producing any error codes. If you have not called for warranty service you do so now. Make sure to tell them that you already have talked to customer support and that unplugging the unit for ANY period of time made no difference in the error code.
Thanks for choosing FixYa.
Kelly
Aug 01, 2010 | Kenmore Kitchen Ranges
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
56 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
