Question about Sound Storm Laboratories SD702 Car Video Player
Screen messed up
I have the sd702 and it just started flashing screen all of the buttons be lit and the screen just flashes and just makes stratching sound no cd play or USB play if you could please tell me something do I need to reset it or something
  • deangelo oliver
    deangelo oliver Oct 20, 2013
    okay i tried to reset it and i get the same results my screen still just flashes i hear the cd spining inside of it and still just flashes white about 5 times and stop
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Display screen does not show picture
Could be your camera is still working, but some settings are messed up?
You could have turned off the display. In the menu with IMAGE DISP. Is used to save battery power.
Then try making pictures in the mode automatic. Because if you switched to scene like bright sunlight or snow your pictures can be very dark.
Jan 16, 2014 | FUJIFILM Cameras
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
Sorry.
Hope this was at least helpfull, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 30, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
Hi i have a k750i flashed to w800i using xs v3.1 now i tried to change the menu icons and got messed up. now when i start the phone the screen shows no image and only the softbar icons.the softkeys...
if you sure that flashing is all that being done to your k750i, flash it again but make sure that you will use the compatible flash file for your k750i.
Oct 13, 2010 | Sony Ericsson K750i Cellular Phone
My main menu screen and monitor "tour" constantly switch back and forth...sometimes my screen flashes between the different viewing modes. All of this just happens and nothing I do to the buttons on the...
csofhaus, First place (thing) I would look is at the monitor's "switch-mode-power-supply!!! When Very Strange things start to occur with LCD back-lit monitors that's the FIRST place I would look for a problem.
12fixlouie
Dec 10, 2009 | Gateway Computers & Internet
Power button keeps flashing
place a game in console push it down and hold it wiggle back and forth until the game is flashing on and off. place another cartiridge on top of the one your holding down, make sure the game screen is still flashing on and off, then hit reset the power light should stay lit and you can play the game. this works for me everytime.
Sep 28, 2009 | Nintendo NES Console
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Aug 10, 2009 | Keurig B60 Coffee Maker
MRM 700 won't start; screen flashes white . . . help.
stonelinton, It's not your LCD, otherwise you would have heard the sound of buttons being pushed. If your units first screen is white and there is no logo screen or any legible images, then it's your NAND flash on your main board. The first image produced upon boot is the blue magellan screen. This is produced from the NAND flash and will show it no matter if a hard drive is present or not. After the Magellan screen it pulls images from the hard drive. So, it is the mainboard and the only way to fix it is to send it to Magellan repair and they will have to put in a new mainboard then reprogram your serial number, etc.
Jun 07, 2007 | Magellan RoadMate 700 GPS Receiver
Sound Storm Laboratories SD702 Car Video Player Logo
26 people viewed this question
Top Sound Storm Laboratories Car Audio & Video Experts
xxxxxx xxx
Are you a Sound Storm Laboratories Car Audio and Video Expert? Answer questions, earn points and help others
