SOURCE: Delonghi Magnifica Rapid Cappuccino machine has
Your problem is the holes in the cappuccino maker and
steam nozzle are clogged. Clean the holes in the cappuccino maker and the steam nozzle.
IMPORTANT: Before cleaning the holes in the steam nozzle, make sure that there that it is not hot and there is no pressure on the machine.
I'm sending you a free pdf manual download of what I believe to be your machine. If this is not it, give me the model # and I will try to find it.
Good Luck!
Jim
SOURCE: Delonghi magnifica 3200. Water not heating up at
Hi Brian,
I have the same machine a EAM-3200 and the no heating problem is the Steam Generator
Cheers Rob.
SOURCE: delonghi magnifica rapid cappuccino model EAM
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
SOURCE: Have misplaced manualfor Delonghi Magnifica
The link for the DeLonghi EAM3200 Espresso & Coffee Maker is below.
http://dl.owneriq.net/6/663b459b-e457-4dff-af70-e6e06698132c.pdf
Testimonial: "ta"
SOURCE: Delonghi Magnifica Rapid Cappuccino machine.
Hi Alan,
This posting is back on the unsolved boards again. I cannot see what anyone else has told you and I don't know what you have tried. So, I'm starting fresh....
If your control panel is not reading that you have inserted the container, then one of several things could be wrong.
I imagine you have already checked and cleaned all the parts involved and made sure that the lids are sealing and the container is seated properly. Clean around the door to be sure it closes securely.
If all of these things are in proper order, then it could be that the control panel has gone bad. Is there a reset button somewhere on your machine? Have you tried to go through the descaling/cleaning procedure and restart the machine?
If none of this works, I would suggest contacting DeLonghi to talk to a technician. Here is a contact page I got from the internet: http://www.delonghiusa.com/index.php?texts&pid=3
You may have already found the contact site, but if all else has been checked and found to be ok, I think that is your only recourse now.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
