Question about LG DLG5988 Gas Dryer
LG DLG5988W DRyER NOT DRYING
Well our dryer stop working for months. I cleaned out the vent and the whole dryer, checked the oms on igniter and gas control valve and 400+ oms were present on both. I suspected the thermostats were not working so I opened the dryer and removed the two thermostats by the fan. I discovered dust and lint all over the thermostats. I cleaned them, and screwed it back on. After I cleaned the dryer and put the dryer back together, the dryer started drying again! oh yeah, buy insurance for your DRYERS, Don't make the mistake of not purchasing it like US!
  • 2 more comments
  • Anonymous Sep 17, 2008
    will not dry
  • Anonymous Mar 23, 2009
    I have the same problem. I am going to try your suggestion.
  • mjrr4 May 19, 2009
    will not dry, it tumbles and sounds like everythig is working but the heat never kicks on............
  • Anonymous Mar 23, 2014
    The dryer stops after a few seconds, it only works on the fan setting. In the back the screws have a star shape so a regular screw driver wont work for opening the back..
  • 489 Answers
Sounds like you have solved your problem.
Posted on Apr 28, 2008
SOURCE:
Where can i get parts for an LG gas dryer number DLG5988W
http://www.repairclinic.com/Shop-For-Parts/a8b200d684294/Model-DLG5988W-LG-Dryer-Parts
Sep 08, 2014 | LG DLG5988 Gas Dryer
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
LG Gas Dryer (Model # DLG5988W) is not heating, the gas is not turning on. When the dryer is turned on the ''Check Filter'' light comes on and when switching to a drying cycle the ?Cool? light is always...
The dryer has a resettable SAFETY thermostat located on the flame tube inside the dryer. LG recommends replacing the Safety and High limit thermostats if the Safety thermostat is tripped. The dryer Glow bar igniter could be bad as well as the gas valve or Main computer. Time to have the dryer serviced by a qualified LG tech. LG has factory service tech in most large cities. Give them a call at 1 800 243-0000.
Hope this helps.
Mike
Oct 31, 2017 | LG Dryers
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
My LG dryer will not power up
You may have a broken door switch.  That would be the most likely source of your problem since the machine will not work if the computer senses that the door isn't closed.
Mar 15, 2008 | LG DLG5932W Gas Dryer
My LG gas dryer DLG5988W
somethin might stuck down insinde the channel where the llint filter goes, small sock baby tee or somethin to that effect, it rests against fan and prevents motor from turning, usually lookin down with a flashlight will confirm this
Mar 02, 2008 | Dryers
LG Tromm dryer now takes two cycles to dry a load
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
Dec 20, 2007 | Dryers
LG DLG5988W Gas Dryer (NO HEAT)
I'm pretty sure that the cooling light is always on and blinks when it is cooling. I look at my brother's and he has the EQ bar and it acts the same.
Dec 04, 2007 | LG DLG5988 Gas Dryer
LG DLG5988 Gas Dryer Logo
728 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
