Question about Sunroof Deflector Toyota RAV4 96-00 56890
I'm trying to find the model number for my 2011 Chery J11 so we can replace a few things but we can't seem to find it anywhere?? Apparently it is the same as a generation 3 Rav4 and we should be able to use those parts to replace the ones we need but I'm really not too sure, so any help would be MUCH APPRECIATED!!! :) Thankyou in advance :)
  • 21 Answers
Hello if you go to www.napaonline.com and click add a car, and then click add vin # it will tell you what make model and production your truck is! And then search for parts and you can use those part numbers to aid you in your repairs. I hope this helps you in your quest Bryan
Posted on Oct 19, 2013
My Chery tiggo 1.6tx 2010 model is jerking while I driving
It depends on how violent the jerking is? Could be as simple as a plug &/or lead breaking down or as complicated as a fuel delivery problem. Sorry not much help, but I don't have much to go on..
Dec 16, 2016 | Cars & Trucks
Is there anything that can be done to the chery tiggo 2.0L uphill performance Since it loose speed very fast from 140 to 110 uphill
need to step on the petro more going up hill perhaps .many do an automatic downshift in hills
Jan 26, 2015 | Cars & Trucks
How do i ? ive a 2012 chery j11 and iam unable to find any info on how to program the keyless remote for it please help regards Dan
The Service Manual says this...
Remote Keyless Entry (RKE) Inoperative
No Response From Remote Keyless Entry (RKE) Transmitter
1. CHECK BATTERY
• Check battery of the RKE transmitter.
Is the battery voltage of the RKE transmitter normal?
Yes >> Go to the next step.
No >> This concern has been caused by the transmitter battery.
Go to step 4.
2. CHECK THE IGNITION LOCK CYLINDER CONDITION
• Check the ignition lock cylinder for proper operation.
Is the check result normal?
No >> Repair or replace the ignition lock cylinder key switch.
3. PERFORM THE RKE TRANSMITTER MATCH PROCEDURE
• Close all the doors.
• Insert the ignition key into the ignition switch which has lost synchronization in LOCK position.
• Press any button on the RKE transmitter within 5 seconds.
• Pull the ignition key out of the ignition switch.
• Try to operate the RKE transmitter.
Does the RKE transmitter operate properly?
Yes >> Erase all codes before returning the vehicle to the customer.
No >> Go to the next step.
4. PERFORM THE RKE TRANSMITTER MATCH WITH THE X-431
• Replace the RKE transmitter.
• Connect the X-431 scan tool to the Data Link Connector (DLC), press the POWER key to start the X-431 (use the most current software available).
• Turn ignition switch on.
? Enter the Diagnostic Program.
? Select Chery main program.
? Select diagnostic version.
? Enter download program.
? Select T11 series, and then select ISU.
? Select Remoter Match.
• Press the lock button on the RKE transmitter for less than 2 seconds.
• Pull out the ignition switch.
The concern was caused by the RKE transmitter.
No >> Replace the FBCM (See FBCM Removal & Installation in Section 15 Body & Accessories).
Refer to the RKE transmitter match procedure with X-431 as the description.
Perform match between the RKE transmitter and FBCM with X-431.
Best wishes from another Chery J11 owner.
You can download the entire service manual from the link below.
Kevin Mullen
Perth WA
Chery Tiggo 2009 Service Manual Page 1699
Nov 18, 2014 | Refrigerators
Cheryl j11 radio beeps and says t p lost
Chery J11 radio beeps and says TP Lost
The Short Answer
This can be pretty annoying as the beep occurs every few minutes. The cause is that the advanced features of the radio are searching for broadcast traffic information, and can't find it.
Generally, only some of the radio stations in major cities carry traffic information, so this feature may not be very useful to you anyway.
To disable the beep, press the TA/AF button on the radio for more than 2 seconds, and you should see AF OFF appear on the display, meaning that the Traffic Announcement Alternate Frequencies feature is no longer searching for (and not finding) traffic information.
Unfortunately, the Chery radio manual doesn't fully explain this.
More...
Traffic Information (TA) Control
Some stations broadcast on the FM waveband have a TP code to signify that they carry traffic programme (TP) information. This is part of the RDS (Radio Data System) used on FM.
Activating traffic announcements
Before you can receive traffic announcements (TA), you must press the TA button. A TA display will appear to show the feature is switched on.
Note: On some units a short press to reach the TA feature.
If you are already tuned to a station that broadcasts traffic information, TA or TP will also be displayed. Otherwise the unit will search for a traffic programme and display TA SRCH or TP SEEK while doing so. If it cannot locate such a station, Not Found or NO TA will be displayed.
Info from
https://www.scribd.com/doc/60900285/audio-guide-1-cg3508en-01-2006
TP lost
If the TP signal of tuned station is lost after 30 seconds, an automatic TP seek for the next TP station will be performed. If no TP station is found, the unit will remain at the current station and display "TP LOST" for 2 seconds, and emit a beep.
TP seek will be performed periodically few minutes until a TP station is found.
Info from http://www.ryedalegarages.co.uk/data/uploads/docs/kia_venga_owners_manual.pdf
Posted to
http://www.cars-directory.net/problem-solving/chery/chery/11154.html
audio guide 1 cg3508en 01 2006
2011 Chery Chery Solving Car Problems chery
Sep 18, 2013 | Car Audio & Video
Chery j11
What To Do When : WIN appears on the dashboard of a Chery J11 SUV : Easy fix just a push of a button...Push the little button with the snowflake on it, it is to the left of the gear shift. This button allows the car to accelerate in 2nd gear in snow or icy conditions. It is also only to be used for this purpose any other use of this switch will burn the gear box out as the internal temperature will become critical fast.
May 29, 2013 | Cars & Trucks
How to reset chery service light model j11
how can i reset the service light on 2011 j11 2.0 chery
Mar 26, 2013 | 2009 Nissan Altima
Creaking handbreak cable on chery j11 even when off and driving
Your cable could be sticking, check it out and the rear brakes too
Mar 16, 2013 | Cars & Trucks
Sunroof Deflector Toyota RAV4 96-00 56890 Logo
Top GTS Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a GTS Vehicle Part and Accessory Expert? Answer questions, earn points and help others
