Question about Poulan Pro " Pro" Self Propelled Mower
How to adjust the pulley tension and cable - Poulan Pro " Pro" Self Propelled Mower
How to replace the power steering belt on a 4g13
ADJUSTMENT
Excessive belt tension will cause damage to the alternator and water pump pulley bearings, while, on the other hand, loose belt tension will produce slip and premature wear on the belt. Therefore, be sure to adjust the belt tension to the proper level.
To adjust the tension on a drive belt, loosen the adjusting bolt or fixing bolt locknut on the alternator, alternator bracket or tension pulley. Then move the alternator or turn the adjusting bolt to adjust belt tension. Once the desired value is reached, secure the bolt or locknut and recheck tension.
REMOVAL & INSTALLATION
1.5L, 1.6L, 1.8L, 2.0L and 2.4L Engines
Fig. Accessory V-belt routing-Mitsubishi 1.5L, 1.6L, 1.8L, 2.0L and 2.4L engines
Alternator Belt
Fig. Loosen the adjuster lock bolt . . .
Fig. . . . then remove the alternator belt from the engine
  1. Loosen the alternator support nut.
  2. Loosen the adjuster lock bolt.
  3. Rotate the adjuster bolt counter clockwise to release the tension on the belt.
  4. Remove the belt.
To install:
  1. Install the belt on the pulleys.
  2. Rotate the adjuster bolt clockwise until the proper tension is reached.
  3. Tighten the adjuster lock bolt and the alternator support nut.
POWER STEERING BELT
Fig. After the adjusting and fixed bolts are loosened, rotate the pump . . .
Fig. . . . then remove the power steering belt from the engine
  1. Remove the alternator belt as described above.
  2. Loosen the power steering pump adjusting bolts.
  3. Remove the power steering pump fixed bolt on the rear of the bracket.
  4. Rotate the pump toward the engine and remove the belt.
To install:
  2. Rotate the pump until the proper tension is reached.
  3. Tighten the adjusting bolts on the pump.
  4. Tighten the fixed bolt on the rear of the bracket.
  5. Install the alternator belt.
A/C COMPRESSOR BELT
  1. Loosen the tension pulley and remove the belt.
  2. The installation is the reverse of the removal.
3.0L DOHC, 3.0L SOHC Galant, and 3.5L Engines
Fig. Serpentine belt routing-Mitsubishi 3.0L engines (except 1998-00 Galant models)
Fig. Accessory V-belt routing-Mitsubishi 3.5L and 1998-00 3.0L SOHC Galant engines
ALTERNATOR AND A/C COMPRESSOR
  1. Disconnect the negative battery cable.
CAUTION Wait at least 90 seconds after the negative battery cable is disconnected to prevent possible deployment of the air bag.
  1. Raise and safely support the vehicle and remove the front undercover.
  2. Loosen the tension pulley fixing nut and relieve the tension on the belt by turning the adjusting bolt.
  3. Remove the belt.
To install:
  1. Install the belt on the crankshaft and alternator pulleys.
  2. Using the adjusting bolt on the tensioner, tighten the belt to the desired tension.
  3. Tighten the fixing nut to hold the adjustment.
  4. Install the undercover and lower the vehicle to the floor.
  5. Connect the negative battery cable.
POWER STEERING BELT
  1. Raise and safely support the vehicle and remove the undercover.
  2. Remove the alternator and A/C compressor belt.
  3. Lower the vehicle and remove the cruise control pump link assembly.
  4. Place the power steering hose under the oil reservoir.
  5. Loosen the tension pulley fixing bolts and remove the power steering pump drive belt.
To install:
  1. Install the power steering pump drive belt.
  2. Insert an extension bar or equivalent into the opening at the end of the tension pulley bracket and pivot the pulley to apply tension to the belt.
  3. Tighten the fixing bolts.
  4. Raise the vehicle and install the alternator and A/C compressor belt.
  5. Install the undercover and lower the vehicle.
  6. Connect the negative battery cable.
3.0L SOHC Diamante
  2. Loosen the lockbolt on the face of the A/C tensioner pulley.
  3. Turn the adjusting bolt of the A/C tensioner pulley to loosen the tension of the A/C belt.
  4. Remove the A/C compressor belt.
  5. Loosen the locknut on the face of the power steering/alternator tensioner pulley.
  6. Turn the adjusting bolt of the tensioner pulley to loosen the tension of the belt.
  7. Remove the power steering/alternator belt.
To install:
  1. Install the power steering/alternator belt first and then the A/C compressor drive belt.
  2. Adjust the belts to the proper tension by turning the adjusting bolts and tighten pulley fixing nut/bolt.
  3. Tighten the mounting nut of the power steering/alternator tensioner pulley to 36 ft. lbs. (50 Nm).
Mar 21, 2013 | 1996 Mitsubishi Mirage
How can i remove timing belt on 2005 kia sedona
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Record the radio anti theft code data.
  3. Remove or disconnect the following:
    Negative battery cable Engine cover Accessory drive belts Idler pulley Crankshaft pulley Power steering pump pulley Belt tensioner pulley Upper and lower timing belt covers
  4. Support the engine with a floor jack and remove the engine mount.
  5. Rotate the engine to align the camshaft sprocket timing marks with the cylinder head cover timing marks.
    Fig. Timing belt routing and timing marks-3.5L Engine
  6. Remove or disconnect the following:
    Auto tensioner Timing belt
    Fig. Timing belt and related components-3.5L Engine
To install:
  1. Ensure that the engine is set to Top Dead Center (TDC).
  2. Prepare the auto tensioner for installation by compressing it in a vise and installing a retaining pin.
  3. Install the timing belt in the following order:
    1. Crankshaft sprocket
    2. Idler pulley
    3. Left bank exhaust camshaft sprocket
    4. Left bank intake camshaft sprocket
    5. Water pump pulley
    6. Right bank intake camshaft sprocket
    7. Right bank exhaust camshaft sprocket
    8. Tensioner pulley
  4. Install the auto tensioner. Do not remove the retaining pin at this time.
  5. Check that the crankshaft and camshaft timing marks are aligned correctly.
  6. Rotate the crankshaft 1 / 4 turn Counterclockwise .
  7. Rotate the crankshaft 1 / 4 turn Clockwise to return the engine to TDC.
  8. Loosen the tensioner pulley center bolt.
  9. Apply 44 inch lbs. (5 Nm) torque to the tensioner pulley as shown and tighten the center bolt to 32-41 ft. lbs. (43-55 Nm).
    Fig. Adjusting the tensioner pulley-3.5L Engine
  10. Remove the auto tensioner retaining pin.
  11. Rotate the crankshaft 2 revolutions Clockwise , then wait 5 minutes for the auto tensioner to adjust.
  12. Measure the auto tensioner rod as shown. If the measurement is not 3.8-4.5 mm, then repeat the belt tensioning procedure.
    Fig. Measuring the auto tensioner rod-3.5L Engine
  13. When the auto tensioner measurement is correct, install or connect the following:
    Engine mount Upper and lower timing belt covers Belt tensioner pulley Power steering pump pulley Crankshaft pulley Idler pulley Accessory drive belts Engine cover Negative battery cable
  14. Reprogram the radio anti theft codes
May 08, 2012 | 2005 Kia Sedona LX
I need to know how to change a timing belt on a 2002 Kia Sendona
  1. Record the radio anti theft code data.
  2. Remove or disconnect the following:
  3. Support the engine with a floor jack and remove the engine mount.
  4. Rotate the engine to align the camshaft sprocket timing marks with the cylinder head cover timing marks.
  5. Remove or disconnect the following:
To install:
    2. Idler pulley
    8. Tensioner pulley
  14. Reprogram the radio anti theft codes.
Feb 06, 2011 | 2002 Kia Sedona
4cyl 2000 honda accord engine stalls while idling, recently died and will only start for short periods... possible problems/solutions?
check for spark and fuel after it dies.
If there is spark but no fuel, then the fuel pump may be bad or a clogged fuel filter.
If there is fuel but not spark, then the ignition control module or the ignition coil could be bad.
Also, check that the timing belt is timing the engine correctly.
Timing Belt & Balancer Belt
2.3L Engine
To Remove:
  1. Record anti-theft code for radio.
  2. Disconnect battery negative cable then positive cable.
  3. Turn crankshaft pulley until TDC is achieved.
  4. Raise and safely support vehicle.
  5. Remove front tire assembly.
  6. Remove splash shield.
  7. Remove power steering belt.
  8. Remove alternator and alternator bracket.
  9. Safely support engine under oil pan.
    Upper bracket removal
  10. Remove stop, detach ground cable and remove upper bracket.
  11. Remove cylinder head cover.
  12. Remove upper cover.
  13. Remove dipstick and tube assembly.
  14. Remove crankshaft pulley.
  15. Remove adjusting nut rubber seal and remove lower cover.
    Timing belt/balancer belt removal
  16. Loosen adjusting nut 1 turn.
  17. Push up on balancer belt tensioner to relieve belt tension.
  18. Push down on timing belt tensioner to relieve belt tension.
  19. Tighten adjusting nut 1 turn.
  20. Remove balancer belt and timing belt.
To Install:
NOTE: Clean balancer belt drive pulley, timing belt pulleys and
upper/lower timing cover prior to belt installation.
  1. Set timing belt drive pulley to TDC by aligning dimple on pulley with dimple
    on oil pump.
  2. Set camshaft pulley to TDC so that "UP" mark is at top and grooves align
    with top of cylinder head.
    Timing belt installation
  3. Starting with driver pulley, install timing belt in a counterclockwise
    sequence.
  4. Loosen and ten retighten adjusting nut.
  5. Install balancer belt drive pulley.
    NOTE: Inspect rubber seal on lower cover and replace as necessary.
  6. Install lower cover.
  7. Install crankshaft pulley and bolt.
  8. Rotate crankshaft pulley counterclockwise several times to seat belt.
  9. Loosen adjusting nut 1 turn.
  10. Rotate crankshaft counterclockwise 3 teeth on camshaft pulley.
  11. Tighten adjusting nut to 33 ft lb (44 Nm).
  12. Turn crankshaft pulley until TDC is achieved.
  13. Ensure that camshaft pulley "UP" mark is at top and grooves align with top
    of cylinder head.
  14. Remove crankshaft pulley and lower cover.
  15. Rotate crankshaft to TDC again and lock timing belt adjuster arm with a 6 mm
    timing cover bolt.
  16. Loosen adjuster nut 1 turn and ensure that belt tensioner freely moves.
  17. Push tensioner up and tighten adjusting nut.
    Balancer shaft alignment
  18. Remove bolt and washer from maintenance hole.
  19. Using a 6 X 100 mm bolt, scribe a mark 2.9 in (74 mm) from end.
  20. Insert bolt into maintenance hole and hole in balancer shaft.
  21. Install bolt up to scribed line.
  22. Align groove on balancer shaft with pointer on oil pump housing.
  23. Install balancer belt and loosen adjusting nut 1 turn to tension.
  24. Retighten bolt.
  25. Remove bolt from maintenance hole and install bolt and washer. Tighten to
    22 ft lb (29 Nm).
  26. Reinstall crankshaft pulley.
  27. Loosen adjusting nut 1 turn.
  28. Rotate crankshaft pulley counterclockwise 1 turn and tighten adjusting nut.
  29. Remove bolt from timing belt adjuster arm.
  30. Remove crankshaft pulley.
  31. Install lower cover.
  32. Install seal at adjusting nut.
    NOTE: Crankshaft pulley, bolt and washer must be cleaned prior to
    installation.
  33. Lubricate crankshaft pulley bolt between head and washer and bolt threads
    with clean engine oil.
    CAUTION
    Do not use impact wrench to perform
    following step.
  34. Install crankshaft pulley and tighten bolt using special tools to 181 ft
    lb (245 Nm)
  35. Install dipstick/tube assembly.
  36. Install upper cover. Tighten bolts to 9 ft lb (12 Nm).
  37. Install cylinder head cover.
  38. Install alternator bracket and alternator.
  39. Install power steering pump belt and alternator belt.
    Upper bracket installation
  40. Install upper bracket and tighten fasteners in proper numbered sequence.
  41. Install stop.
  42. Install battery and enter radio anti-theft code.
Oct 29, 2010 | 2000 Honda Accord
How to remove alternator on a 2005 range rover
Hi
Click here
the link above should tell you all you need to know if you get stuck or have any problems give me a shout back ok
Oct 26, 2010 | Land Rover Range Rover Cars & Trucks
I need a diagram to see were my tension-er is
I don't have the figure for your car, but the below figure shows how to remove the A/C belt.
the other belts should have a simple slot in the bracket for adjusting. If you have more questions, let us know.
3.0L SOHC Diamante
To install:
NOTE The manufacturer does not provide a torque specification for the bolt that secures A/C tensioner pulley.
  1. Connect the negative battery cable.
Oct 06, 2010 | 1994 Mitsubishi Diamante
How to change alternator belt
alternator and air conditioning compressor
  2. Loosen the idler pulley bolt.
The replacement of the inner belt on multi-belted engines may require the removal of the outer belts.
To replace a drive belt, loosen the adjusting and mounting bolts of the component which the belt is driving. Move the component inward to relieve the tension on the drive belt.
Slip the belt off the component pulley and match the new belt with the old belt for length and width. The old belt will be slightly longer. After a new belt is installed correctly, adjust the tension.
  1. Turn the adjustment bolt at the top of the idler pulley bracket. Clockwise rotation will tighten the belt; counterclockwise will loosen it.
  2. Keep the idler pulley bolt snug (but not tight) while adjusting belt tension. The adjustment bolt should turn with moderate force.
After adjustment is satisfactory, tighten the idler pulley bolt, and then tighten the adjustment bolt.
Reconnect the negative battery cable.
When replacing more than 1 belt, it is a good idea to make note or mark what belt goes around what pulley; this will make installation easier if you mix up the belts.
Sep 25, 2010 | 1997 Nissan Maxima
How do I change a water pump on a 2004 kia sorento?
Kia Sorento 2003-05
Water Pump - Removal & Installation
  2. Drain the cooling system.
  3. Disconnect the negative battery cable.
  4. Remove the drive belt and the water pump pulley.
  5. Remove the timing belt cover, timing belt, auto tensioner and idler pulley.
  6. Remove the water outlet fitting, the thermostat case and the water pump fitting.
  7. Remove the water pump mounting bolts.
  8. Remove the water pump.
    Fig. Water pump and timing belt assembly-exploded view
To install:
Fig. Water pump bolt locations
  1. Clean the gasket surfaces of the water pump body and the cylinder block.
  2. Install the new water pump gasket and pump assembly. Tighten the bolts to 12-16 ft. lbs. (17-22 Nm).
  3. Install the water pump fitting, the thermostat case and the water outlet fitting.
  4. Install the auto tensioner and timing belt. Adjust the timing belt tension, then install the timing belt cover.
  5. Install the drive belt, water pump pulley and then adjust the auto tensioner.
  6. Refill the coolant.
  7. Run the engine and check for leaks.
  1. Before servicing the vehicle, refer to the Precautions Section.
To install:
Fig. Water pump O-ring installation
  6. To adjust the drive belt tension, hang the belt on the pulley of the tensioner and install the tensioner.
    NOTE If the tensioner is already installed, loosen its mounting bolts to allow belt installation
  7. Install the drive belt.
  8. Adjust the belt tension to specification by turning the adjusting bolt clockwise or counterclockwise.
  9. Air conditioning belt tension should be 0.28-0.039 inch. Alternator belt tension should be 0.39-0.051 inch. Power steering belt tension should be 0.31-0.051 inch.
  10. Torque the tensioner assembly bolt to 33-36 ft. lbs. (45-50 Nm).
  11. Refill the coolant.
  12. Run the engine and check for leaks.
TY for using Fixya; remember comment and rated this.
Apr 01, 2010 | 2004 Kia Sorento
1998 Dodge Avenger serpentine belt issue
What size of motor, do you have a/c and which belt are you replacing? Not sure about your engine size since you did not list it so please pick the applicable motor:
Sebring Coupe And Avenger (2.5L VIN N Engine)
  2. Loosen the tension pulley locknut.
  3. Rotate the adjusting bolt to decrease the belt tension.
  4. Remove the drive belt from the engine.
To install:
  1. Position the replacement belt around the pulleys, making sure the belt routing is correct.
  2. Adjust the belt by rotating the adjusting bolt until the correct tension is reached. Refer to the procedure earlier in this section for belt adjustment.
  3. Once the desired tension is reached, secure the locknut. Recheck the belt tension.
  4. After the belt is installed and adjusted properly, tighten the locknut to 17 ft. lbs. (23 Nm).
2.0 DOHC
Power Steering Pump And A/C Belt
To install:
  4. After the belt is installed and adjusted properly, tighten the locknut.
Oct 29, 2009 | 2000 Dodge Avenger
I have to replace the alternator but don't know how to loosen the belt tension
Removal & Installation When replacing a serpentine belt, insert a 1/2in. breaker bar into the slot provided on the self-adjusting belt tensioner and pry up enough to slip the belt out from under the pulley. During installation, DO NOT allow the tensioner to "snap" back. Be sure to release the tensioner pressure slowly onto the belt.
  1. If you are working near a battery, disconnect the negative battery cable. This is also advisable in order to prevent personal injury should someone try to start the engine while your hands are near the radiator fan or on a drive belt.
  2. Loosen the mounting and adjusting bolts on the component whose belt is going to be removed.
  3. Pivot the component inward toward the engine and slip the belt off the component's pulley.
  4. Remove the belt from the crankshaft pulley, then remove the belt from the vehicle.
To install:
  1. Position the belt to the engine and over the pulleys.
  2. Properly adjust the belt by pivoting the component outward until the proper tension is achieved, then tighten the mounting and adjusting bolts.
  3. Reconnect the negative battery cable.
Oct 11, 2009 | 1989 Buick Park Avenue
Poulan Pro " Pro" Self Propelled Mower Logo
50 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
