Question about Welding Tools
I have a Miller 60 series 24v. wire feeder a old Lincoln shield ark welder model 300 ser#675676 1800 R.P.M. 240/480 volts Code#6967 That runs and welds fantastic is there any way possible to wire the wire feeder to the Lincoln welder.
luxur4
  • 92 Answers
SOURCE: lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Posted on Jan 23, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
97F350diesel
  • 1326 Answers
SOURCE: My lincoln welder lost its heat penetration
It only produces 100amps. You can only weld thinner metal 3/16" comfortably. Any thicker will resuld in less/no penetration.
Posted on Sep 22, 2009
KrisJohn1
  • 7 Answers
SOURCE: Lincoln Weld Pak 100 arc welder troubleshooting
There can be a switch that makes the wire electrically "dead" so it can be fed through the liner. Also suitcase style welders have a sensor wire with a clamp that must be connected for the arc to be able to be struck.
Posted on Nov 24, 2009
  • 52 Answers
SOURCE: my sp 135 welder is burning the wire
The wire will burn back between wherever it gets the power, to wherever it is grounded. If it burns back to the rollers, it must not be getting power at the contact tip.
Remember, if you are using a shielding gas, the gun wires up to the (+). If you are using flux core, the gun wires to the (-).
Of course the 'ground' connects to the opposite.
Sounds like the drive rollers are shorted to 'ground'.
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Miller welder problem
    the current setting is not working correctly
    indicates that the amp setting for the wire is too low or if it is an inverter , the volts setting is far too low
    Jul 26, 2017 | Welding Tools
    Wiring diagram for miller bluestar welder ser. JE817646
    http://www.millerwelds.com/service/ownersmanuals.php?model
    If you see a model that is close in description in the Blue Star models, such as a "145" the wiring diagram should be close if not the same. Otherwise select from the list the Blue Star with the same engine type as yours.
    The If the tag is not damaged, and truly a JE series, you can download all the Blue Star manuals to find the one that has your serial number in the range. Miller is good with manuals, but sometimes the cross reference to just serial number does not work.
    Dec 17, 2011 | Welding Tools
    Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
    It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
    Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
    When I go to weld the wier will feed but it will not strkie an ark
    Hi:
    I suposse that you are using a wire briefcase (?), if so there is only one lead from the wire feeder to connect to the engine drive, that one goes to (+) stinger side and the briefcase has one volt sensing clamp, this one goes to your metal piece as same with the ground cable from the engine drive. If still you don't have a spark using the wire feeder but you do with the engine drive (stick welding) then your problem is your gun.
    Email back if need more troubleshooting.
    If this was useful to you please vote, thanks.
    Mar 05, 2011 | Miller Trailblazer 302 Welder Generator...
    How i can use wire feer x-tyrem with a cp-302 welder
    Hi:
    An easy one: Connect your Suitcase X-treme 8 or 12 VS (volts sensing) as follows:
    Weld Cable (+) To Feeder lead cable.
    Work Cable ( - ) To Workpiece Weld cable and work cable connections to power source (DCEN/DCEP) are dependant on wire type.
    Since feeder is not polarity sensitive, there is no need for an electrode polarity switch.
    Voltage Sensing Clamp Connect voltage sensing clamp to
    workpiece.
    Gas Hose to regulator.
    Gas Cylinder to regulator.
    Use of shielding gas is dependant on wire type.
    You are all set up to weld.
    If this was useful. Please vote.
    Feb 22, 2011 | Miller Electric Mfg Co 903376 Deltaweld...
    How do you hook a miller s-22p8 wire feeder to a lincoln ranger 10,000 plus engine driven welder?
    you can't, the S-22P8 it's not a volt sensing wire feeder, it requires 24V or 115 with an adapter. FOr CV machines only.
    Dec 08, 2010 | Miller Electric Mfg Co 903376 Deltaweld...
    Wire from gun arks without trigger pull
    Some old miller has a contact box inside the machine, this box could be worn out and needs to be replace. New miller have PC boards now. also these ones need to be replace.
    Aug 05, 2010 | Miller Welding Tools
    Im tryint to conect my wire feeder
    ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
    Dec 19, 2008 | Welding Tools
    Miller axcess 40v wire feeder
    give me a day or so and i will have the solution for you
    Sep 11, 2008 | Welding Tools
    Welding Tools Logo
    103 people viewed this question
    Top Welding Tools Experts
    Bill Boyd
    Are you a Welding Tool Expert? Answer questions, earn points and help others
