Question about Vehicle Parts & Accessories
Astra van alarm prolem
Hello wondering if you could help,my alarm keeps going off someone said it could be the sensor and turning it down will sort you know where id find the sensor.i have a w reg vauxhall astra van 1.7 td.thanks ty.
  • Anonymous Dec 06, 2008
    Alarm sounds intermittently.
My alarm keeps goin of in my vauxhall astra o2 plate
Posted on Nov 18, 2010
  • 143 Answers
Most units are fitted behnd the glove box a couple of screws in it & under it, and the whole thing will come out.
if it has an adjustable sensor then there could be a small hole with a - + a small screw driver turns it up or down, it could well be one that needs programing via software inother words there is a set up sequence which puts the alarm in programing mode...
It depends on the manufacturer. (WHAT ALARM IS IT?)
Posted on Dec 22, 2007
Alarm keeps going, car locked or unlocked
Hopely this trick is useful.
1. Open the window.
2. Disconnect the battery.
3. Close the door. (Keep the window open)
4. Turn the ignition key on.
5. Find the hood sensor in engine bay area. (It looks like push button)
6. Press the hood sensor and reconnect the battery. (Keep pressing the sensor)
7. Ask someone to start the engine (Keep pressing the sensor)
8. After the engine start, you can release that sensor.
9. Now your alarm vehicle was deactivated.
This trick is effective for common mitsubishi car which not using immobilizer.
Mar 08, 2015 | 2006 Mitsubishi Grandis 2.0
Cannot turn off car alarm on my vauxhall astra keyless system i have disconected the battery but it is still going off
Your Astra must have a backup battery, have to find the unit and disconnect the backup battery to stop siren
Feb 15, 2014 | Scytek Electronics ASTRA7E7 Car Alarm -...
Skytec astra alarm system keeps losing power
The batteries take a lot of power to send and receive data so you should get around 3 to 4 weeks per battery. If this is what you get it is normal.
Oct 01, 2013 | Scytek Electronics ASTRA200 Car Alarm 1...
Ford Windstar has anti theft alarm & if van is hit it is suppose to go off but it did not go off when car was hit and back hatch was caved in.Can it be fixed.
Hello, The Factory Alarm installed in your van does not do this. If you have an Aftermarket Alarm it has to have a Vibration sensor to perform like you imagine and want. There is no Impact sensor for the Alarm from the Factory.
The Impact sensor your van does have from the Factory is for cutting off the fuel pump in case of a crash. It is a silent switch and has a frequency that needs to be reached before working.
You can have an Aftermarket alarm installed to make a noise if your van is hit or rocked. The damage on your hatch can be fixed and it depends on the type of damage it sustained to know what is needed to make it right.
I hope you find mt solution very helpful.
Jul 19, 2011 | Ford Windstar Cars & Trucks
Alarm keeps going off. what is the problem which fuse can i remove?
it is most likely going off because the sensor that sets the alarm off when someone bangs it or breaks the window is set to sensitive. Locate the adjustment under the hood near the firewall usually on the alarm module and turn it down.
Sep 19, 2010 | 2005 Chevrolet Cobalt
Annoying alarm dinging until van reaches 17mph
This means one of the door ajar sensors is stuck. You need to remove the door trim panel and then the latch and then the sensor. Once out clean and lube it. There is a sensor inside every door.
Mar 16, 2010 | 1998 Ford Windstar
My 1994 caravan drives about 200 feet then starts slipping.If I turn the ignition off and back on it will go another 200 feet.friends told me it is some sort of sensor .does any know whats going on .thanks
Please define the word "slipping" for me. To me it means the transmission is "slipping", the van is going down the road, and then the engine RPM's are still there, but the van keeps slowing down ? You try to put on more acceleration, but the engine revs up higher, but you go nowhere ?
Please let me know.
Feb 17, 2010 | 1994 Dodge Caravan
2000 Astro Van factory alarm activates and won't start
dont not cut any wire find a alarm technician and ask them disable for you unit is link to vEhicle ECM DONT CUT AND FOR THE SAKE OF CUTTING MAKE SURE THIS DONT BY SOMEONE WITH KNOWLEDGE
Aug 07, 2009 | 2000 Chevrolet Astro
Engine 1 fuse keeps blowing when you turn the key
sounds as if you have a power shortage in the van. first establish what fuse keeps blowing this will help in narrowing down the short.once short is located check all connections ,wires,and plugs.
Jul 12, 2009 | 1999 Chevrolet Express
Chrysler sebring 1999
Sounds like you fried something when you jumped it. Make sure all the cables and wires are good and not burnt. Check fuses, and replace as necessary.
Jun 04, 2009 | 1999 Chrysler Sebring
Vehicle Parts & Accessories Logo
405 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
