IR codes LG minisplit - Heating & Cooling
I have a LG minisplit (indoor unit LSN122HE /outdoor unit is LSU122HE) it cools great dehumidifies also and has for 3 months of summer. However its cold now and it will not heat. It runs for a min out
That's an inverter series motors... the outdoor fan motor is on an ambient controller to maintain pressures when cold outside in air conditioning mode, but not in heat...only defrost when needed. Check the settings on the outdoor board for defrost timing
Dec 02, 2013 | LG LSN122HE / LSU122HE - 11,500 BTU 13...
Codigo de programacion taika modelo tkb-ac
Tengo un control remoto marca taika TKB-AC y Busco el codigo de programacion para un minisplit marca LG
Traductor: I have a remote control taika brand TKB-AC and the programming code looking for minisplit brand LG
Nov 10, 2013 | Televison & Video
Program remote to LG TV
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for addressing your remote to your TV for each of our different models of remotes. You should be able to locate your remote model number on the back of the remote at the top usually a 2 to 3 digit number with a decimal point. I will list here for you the best codes for our more popular models of remotes and the instructions for addressing your remote to your LG TV. I hope you find this information useful and if you have any further questions feel free to email me directly at Cheri.Torres@Dishnetwork.com.
Codes for a LG TV
3.0, 3.1, 3.2, 3.4 IR remotes - 678, 506, 520, 627, 766, 211
5.0, 5.2, 5.3, 5.4 IR remotes - 520, 505, 678, 512, 766,
4.0 and 4.4 IR/UHF remotes - 678, 156, 520, 023, 627, 766
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - 520, 654, 678, 564, 506, 500, 627
20.0 IR remote and 21.0 IR/UHF remotes - 627, 505, 520, 553, 773, 718
Instructions for addressing the remote to the TV
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all the mode lights light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Apr 17, 2011 | DISH Network IR Remote Control
Brand to pick to promgran a lg tv to dish remote for power on , ect ?
Hello, this is Cheri Torres with DISH Network customerservice. I came across your questions and wanted to see if I could help. :)There are a few codes that you can try to program to your remote in order toget your remote to perform the TV functions. We have different codes fordifferent models of remotes. You can find the model number of your remote onthe back of the remote at the top. This model number usually consists of a twodigit number with a decimal point i.e. 3.4 etc. I am going to list thedifferent codes for each of our most common IR remotes. For the 3.0 IR remotethe codes that work most often are going to be 678, 506, and 520. For the 3.1IR remote 520 and 506 are the most commonly used. For the 3.2 IR remote 506,627, and 520 are the best codes. The codes for the 5.0 IR remote are 505, 520,and 678. For the 5.3 they are 520 and 766. The 5.4 IR remote is the last remoteand the code is 766. I hope you find these codes useful in getting your IRremote addressed to your LG television. If you have any further questions orconcerns feel free to post back here and I would be happy to help. :)
Dec 12, 2010 | DISH Network IR Remote Control
I have a minisplit unit that leaks out the freon
try leak stop that they sell for refrigeration and air conditioning systems
Dec 12, 2009 | Heating & Cooling
Lg minisplit heat pump will not heat
You may want to check that the pressure switch is not functioning? Secondly there is also a thermo sensor on the condenser coil which could be faulty.
Feb 26, 2009 | Heating & Cooling
My LG remote control turns two TV's on simultaneously
I had the same problem and we cut up a stick on lable and placed it over the end of the remote . It weakened the signal enough to where it would not change the other tv/tvs. We colored in the white lable with a black marker and you dont even notice it there.
It took alittle playing around with but it was much cheaper than buying a remote.
Dec 01, 2008 | LG Shine KE970 Cellular Phone
Minisplit flashing code - water dropping
Check your air filter and indoor coil fins if clean. If it is dirty it need to be clean. But if it is clean you need a qualified technician for this problem.
Jul 30, 2008 | Heating & Cooling
IR Codes for LG ductless air conditioner
I, have a LS120cp lg ductless.The only way I,can get the unit to run is by pressing the test button on outdoor board.
Jun 04, 2008 | LG Heating & Cooling
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
