Question about nanobitsoftware.com Tap & Track -CalorieWeight & Exercise Tracker
I have tap and track and it will not sync, last sync was August 22, 2013. When I try to sync, error pulls up to contact team support, where do I go for support?
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
Tip
How do you Sync Facebook Pictures with Contacts on your Android Phone
<p>Android phones continue to be a group of phone contacts stored on the Google "Contacts" application device, but synchronizes contacts with other services such as Facebook and Twitter to use. This results in duplicate contacts, only some of the information on each individual offer. If you combine the contacts you can sync contact with the image of a Facebook phone contact for quick recognition. <br /> <p><br /> <p>1. Setting up your Facebook account to sync with your phone. Check the configuration of the account "Accounts & Sync Settings section 'of the" Settings "app. Touch a disabled account, select" Synchronize Contacts "to activate it, or tap" Add Account "to the new Facebook account in the phone. <br /> <p><br /> <p>2. Touch the "Contacts" icon in the application menu, or open the phone dialer on the Quick Start section and tap "Contacts" tab. Press "Menu" and select "Display Options." <br /> <p><br /> <p>3. Tap the drop-down arrow next to your Facebook account and check the "All Contacts" box to ensure the Facebook contacts are displayed correctly. You can disable the Facebook contacts to show when ready. Press "Back." <br /> <p><br /> <p>4. Scroll down and tap the contact you want to sync to a Facebook photo. You can choose whether the phone or contact Facebook, but if the two names together last contact will use the name you select. Press the "Menu", click "Edit Contact" option. Press "Menu" and select "Join". <br /> <p><br /> <p>5. Scroll down and touch the second version of the list of contacts. The two contacts together in one item and leave your Facebook picture. Tap "Done" to save the settings. <br />
on Aug 18, 2011 | Google Android
Tip
Contact Numbers How Facebook Mobile Phone Sync
<p>If you have an iPhone or Android phone, you can sync your Facebook contacts to your phone. Otherwise, if another mobile phone, the synchronization feature of Facebook contacts may not be available. Android and iPhone smartphone users have it easy. With a few taps, you can configure the synchronization feature; the Facebook application handles the import and exports your contacts from that point forward. <br /> <p><br /> <p>Android <br /> <p>1. Put on your Android phone, and go to the home screen. <br /> <p><br /> <p>2. Touch the "Facebook" icon and press the "Menu" button on your phone. Touch the "Settings" from the pop-up. <br /> <p><br /> <p>3. Scroll down to the bottom, and tap the "Sync Contacts" option. <br /> <p><br /> <p>4. Choose what to synchronize. Your options include "Sync All" or "Sync existing contacts." The last option is just to sync contacts from Facebook with people aligned with your "Contacts" app exists. If the person is not there, it will not sync. I want all your Facebook contacts to your phone to get, then you choose "Sync All". <br /> <p><br /> <p>5. Touch the "OK". Facebook will start regardless sync contacts in the background when the application is running or not. Every time your contacts are updated, it will also synchronize the data. <br /> <p><br /> <p>iPhone <br /> <p>1. Turning your smartphone iPhone, and go to the home screen. <br /> <p><br /> <p>2. Touch the "Facebook" icon to start the app, and then the "Friends" icon in the app yourself. <br /> <p><br /> <p>3. Tap the arrow at the top right and select "Sync Contacts". <br /> <p><br /> <p>4. Move the slider to "Synchronize" to "ON" position. <br /> <p><br /> <p>5. Tap the "Sync Contacts" button after reading the disclosure law. The synchronization process should begin immediately, as well as your Facebook friends and downloads their photos to your profile "Contacts" app. <br />
on Aug 18, 2011 | Facebook Social Network
After dialing a number there is a delay of about 15 seconds before the call goes through
If you search online for this issue you will find many people telling you to root your phone, to delete the cache, etc. In my case I solved it by synchronizing all contacts again. Do you use your google account to sync them? If you do, then follow these steps below:
Try this:
0- Make a backup of all your contacts. This is only for safety, but its HIGHLY recommended.
1- Download any app from google play to delete all contacts. I used Contact Remover
2- Go to Accounts and Sync
3- Tap on your google account so you see all that your are synchronizing.
4- tap on the menu button and tap on Remove Account option.
5- Open the Contact Remover app and delete all contacts from the phone
6- Add back your google account and wait for it to sync all your contacts again
Dec 02, 2013 | Lands Phones
How do I transfer my aol contacts to my ipad
You can follow these instructions to download and install the Funambol plug-in. With Funambol installed, you'll be able to sync your AOL Contacts to your iPad.
Here's how:
1. Tap the App Store on your home screen to open it.
2. Search for the Funambol app.
3. Next to the Funambol app, tap FREE (since this app is free, there might only be an INSTALL button).
4. Tap INSTALL.
5. The Funambol Sync client will start to download and install on your iPad.
6. Wait until the installation is complete.
Here's how to Sync AOL Contacts to your iPad:
1. Start Funambol from your home screen.
2. Tap OK on the credential alert.
3. Set the server to http://msync.aol.com/sync.
4. Set the Username to your AOL Username.
5. Set the Password to your AOL Password.
6. Tap Funambol to return to the Funambol home screen.
7. Tap Sync Contacts to start the synchronization.
Jul 11, 2012 | Computers & Internet
My cpu doesnt turn on,then it turn off back\
Try to get into safe mode by tapping F8 repeatedly. You can also try the Last Known Good Configuration option.For technical Support, I suggest you contact The Best Pc Doctor Team.
www.thebestpcdoctor.com
877 407 9229(Toll free)
Oct 13, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
E728 emachine will not start windows
Is there any error message being displayed?Try to get into safe mode by tapping F8.For technical Support, you can contact The Best Pc Doctor Team.They provide the best support in this field.
Oct 12, 2011 | E-Machines eMachines Desktop PC
I have a LG Ally and I accidently synced my contacts from facebook. Its getting annoying when I'm trying to find a number. How do I de-sync the facebook contacts?
Follow these steps:
- Go to your Settings, either find the "Settings" icon in the App Drawer, or tap the menu key while on the home screen.
- Tap Accounts & Sync
- Tap your Facebook account under "Manage Accounts" It should have a blue icon
- Tap the box next to "Sync Contacts" to uncheck it.
You should also go into Socialite and do the following (if you used it to set up your Facebook account):
- Open Socialite from the App Drawer
- Tap Facebook
- Tap the menu key
- Tap Settings
- Scroll down and check to make sure that the setting under "Facebook Contact Sync" is "Don't Sync." If it isn't, tap the entry and then choose "Don't Sync" from the list that appears.
You should also check any other Facebook applications you may have installed to see if there is anything about sync in their settings. Once you do this, your Facebook info should no longer appear in your contacts.
If this helped you, help me with a few thumbs up!
Dec 23, 2010 | LG KM555 Cell Phone
I cant sinc my i phone as it says unable to connect to i tunes store.
Please follow the steps below to resolve your sync issues which applies to iPhone, iPad, or iPod touch. If you make changes during any of the steps below, try syncing again with MobileMe on your iPhone, iPad, or iPod touch.
  1. If you are syncing calendars or contacts, view the data on MobileMe Calendar or MobileMe Contacts. If the data does not appear to be correct there, the issue is not with your device. If you are syncing using a Mac, see this article for more information. If you are syncing using a PC, see this article for more information.
  2. Make sure your device is up to date with the latest software. To make sure your device is up to date, connect it to your computer, open iTunes, and click "Check for Update."
  3. On your device, make sure you are able to connect to the Internet. For example, open Safari on your device, then browse to http://www.apple.com . MobileMe requires an Internet connection to sync. (A 3G or WiFi connection is recommended during setup or when following many of the steps below; they may require several minutes via an EDGE connection.)
  4. Confirm that a sync is not already occurring. If a sync is occurring, the activity spinner (in the status bar) will display while looking at Safari Bookmarks (if Bookmarks are currently syncing), Calendar (if calendars are currently syncing), or Contacts (if contacts are currently syncing). If a sync is occurring, wait for the sync to complete, and then see if your data is up-to-date.
  5. Make sure you are looking at your full set of contacts or calendars. When configuring your MobileMe account in iOS 3.1 and later, you will have a choice to Merge or Don’t Merge your data. If you choose Don’t Merge, your MobileMe data is kept separate from the data that was already on your device. In Contacts/Calendars, tap the button in the upper left corner until you are able to see all Groups or Calendars, and verify that you are looking at your MobileMe data.
  6. Confirm that you are able to get your MobileMe Mail on your device. If you receive an alert message when attempting to get your MobileMe Mail, your account may not be configured correctly, or you may not have a reliable internet connection. If the alert message is about your username or password being incorrect, go to the next step.
  7. Verify your MobileMe account is configured correctly on your device:
    1. On the home screen, tap Settings > Mail, Contacts, Calendars.
    2. Tap Fetch New Data, and make sure Push is turned On. Tap Mail... to go back one screen.
    3. Tap your MobileMe account.
    4. Tap Account Info and check the Address field.
    5. Verify that your address appears correct (it should appear as your MobileMe email address, such as membername@me.com or membername@mac.com). If your account does not appear as expected, see the “Delete and re-add your MobileMe account” under the Advanced Troubleshooting section below.
    6. If you received an alert about your username or password during step 6, delete and re-enter your MobileMe password, and then check your Mail again. If your still receive the same message, try logging into www.me.com. If you are unable to log in, see this article.
    7. If your account does appear to be entered correctly, go back one screen and confirm the sliders for the data that you want to sync are set to On.
  8. Verify that your device is connected to the MobileMe service. To confirm this, visit http://www.me.com/find from a computer. Because Find my iPhone relies on the same connection as MobileMe Sync, your device should be listed as "Online" for as long as it has an active Internet connection. If the device does not appear as expected, please see this article about troubleshooting Find My iPhone.
  9. Restart your device: Hold the power button until "slide to power off" appears. Slide to power off. After it is off, press the power button to turn it back on.
  10. Wait an hour and try again. Apple may temporarily disable an account from syncing with MobileMe if it is determined that an account may be taking longer than normal to sync. By waiting an hour and trying again, this allows for the previous sync to complete. If you find your account encounters the issue again, go to the Advance troubleshooting section.
If the above steps do not resolve your issue on your iPhone, iPad, or iPod touch, you can try these advanced troubleshooting steps:
Turn all syncing off and then back on
From the home screen, tap Settings > Mail, Contacts, Calendars, and then tap your MobileMe account. Tap the sliders off for each account that your are syncing. If prompted to do so, tap "Keep on My iPhone" (or iPad/iPod touch). Turn your device off and back on, then re-enable syncing. If prompted to do so, choose Merge with MobileMe. Wait a few minutes, and try syncing again.
Isolate the issue to a specific data type
If the above did not resolve the issue, once again turn off all syncing, and then test each data type one at a time. For example, if Contacts syncs successfully, but Calendars does not, focus your troubleshooting on Calendars.
If you have isolated the issue to either Contacts or Calendars that are not syncing successfully (one works, the other does not), see this article recommendations about how to clean up that data on your Mac or PC, as it is likely causing the issue.
If none of the above steps resolve the issue, make sure you have a copy of all Contact, Calendar, and Bookmark data on your device saved on your Mac/PC. From the home screen, tap Settings > Mail, Contacts, Calendars, and then tap your MobileMe account. Tap Delete Account. (If prompted to do so, choose "Delete from My iPhone" (or iPad/iPod touch). Restart your device. After it restarts, on the Mail, Contacts, and Calendars screen, tap Add Account > MobileMe, and set up your account again.
Aug 15, 2010 | Apple iTunes
Sync is currently experiencing problems
I had the same problem and resolved it next way. First backed up all my contacts on G1 with myBackup, then deleted all my contacts on Google from laptop. Autosync all the time was on, so all contacts was deleted from my G1 also. After that I restarted the phone, and restored my contacts with myBackup. When my G1 tried to sync it asked me what to do, because it have too many items to delete (from "All contacts" category on Google). I've chose "delete". You may try other choice. After few minutes I've had exact all my contacts from G1 on Google no less, no more, and no sync error. Remember: just in case, backup all your contacts on G1 or Google before deleting them, to prevent them from beeing lost!! Good luck.
Oct 27, 2008 | HTC G1
nanobitsoftware.com Tap & Track -CalorieWeight & Exercise Tracker Logo
481 people viewed this question
Top nanobitsoftware.com Apps Experts
Erin Wood
Erin Wood
Are you a nanobitsoftware.com App Expert? Answer questions, earn points and help others
