Highcool sw187 E3 fault - Heating & Cooling
Model wf361. What is causing e3 error?
e3. Drive motor tach fault. This means that the tachometer is not regitering any motor movement when it should. Main reasons for samsung: motor control board fault. Tachometer fault. Motor fault. Also check wireing from motor control board to motor. But this issue is not common at all with samsung.
Feb 15, 2016 | Samsung Washing Machines
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Aug 09, 2008 | Kenwood KW85 Air Conditioner
What is error code E3 in washing machine Beko 91242 LC
This error code is below. Good luck to you:
E3
Constant heat
Nov 25, 2014 | Beko Washing Machines
E3 Error Message
E3 indicates a sensor fail - most probably the humidity sesnsor. Or it could be a fault in the display itself. Are all the functions working properly?
May 28, 2013 | Humidifiers
Kenwood diswasher kdw243a/a e3 fault code?
e3 means there was a longer heating time but not reaching required temperature could be a malfunction of temperature sensor or of heating element. E3 is a temperature error. There are two theromstats, 90 degrees and 78 degrees. I suggest you to call the competent person to substitute either of these thermostats.
Jun 05, 2011 | Dishwashers
Code reading E3 F-1
Thank you for using FixYa. F1 refers ro a fault with either the control board or touch pad. Both may need replacing to clear this error. E3 refers to a fault with the temperature sensor and should be replaced. This unless the repair done by yourself may work out expensive.
Sorry to be the bearer of bad news.
Mar 04, 2011 | Ovens
Error : E3 FAULT
i have problem ac indoor come on display e3 error problem kindly give me solution
Sep 16, 2008 | Kenwood KW85 Air Conditioner
No start
e3 fault??? sounds like an open sensor, located right nest to the thermaal fuse.
May 08, 2008 | Whirlpool GEW9200L Electric Dryer
Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Mar 08, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Fault E3
Oct 28, 2007 | Kenwood KW85 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
