I have a Sharp SPL-TXC15A paper shredder that runs constantly if I don't manually shut it off
macrule413
SOURCE: Ativa SPL 1506X not working
I had the same "click" noise when trying to shred. I had a Staples replacement guarantee (extended warranty) so I called them up and described the issue. They are sending me a gift card for the purchase amount. Seeing as they did not want the original unit back I decided to take it apart to see if I could find the problem. I did not find an issue with the gear as the other user stated but I did notice a burn mark on the circuit board just under the relay (which could make a click noise) I removed and inspected the relay (desoldered), but I could not see anything wrong with it so I re-soldered it back onto the board and re-soldered (re-flowed) all of the other connections just in case there was a cracked joint. Upon testing the shredder still has the same "click" sound. My guess is there is a faulty device on the circuit board such as a resistor or relay. To sum it up, to repair this particular issue you will be unable to implement a "simple" fix and it would realistically require either a new circuit board or a whole new shredder.
Posted on Jun 22, 2008
  • 35 Answers
SOURCE: I HAVE A MODEL SPL-1506X PAPER SHREDDER, YOU HEAR
The optics are OK!
There is a small electromagnetic sensor on the cuttershaft which senses the input load.
I could be maladjusted or defective.
Posted on Feb 23, 2009
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
SOURCE: Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
http://www.radioshack.com/product/index.jsp?productId=3107633
Posted on Jul 04, 2010
cjspizz
SOURCE: how do I get an
I've scanned my manual for the SPL-TMC10A. You can find it here: http://bit.ly/pom1I5
Posted on Jul 31, 2011
I have a Staples SPL-TXC15A shredder that doesn't start when paper is inserted. The power light is on and it runs in reverse but won't start when paper is inserted.
You need to change the direction or travel switch. Auto will only work when the direction of travel is into the bin, but you probably know that. There is an interlock on it. Use a vacuum cleaner crevice tool and then the brush attachment on both sides of the head. If that doesn't work, my guess is that the forward reverse switch is faulty. You would need to strip it apart and check with a meter.
Jan 03, 2017 | Kitchen Appliances - Others
What lubricant do you use for a Staples SPL-XC240D and where do you lubricate it?
Staples actually sells shredder lubricant. It comes in a small squeeze bottle. You actually are lubricating the shredder teeth themselves to keep them sharp and prolonging their lifetime. You simply take a piece of paper you are about to shred, run a bead of the lubricant across the sheet and feed it into the shredder. Done!
Mar 04, 2015 | Staples Office Equipment & Supplies
Model SPL-TXC15A. Why doesn't it operate?
The shredder may have gone into thermal overload as a result of trying to shred something unsuitable, such as a credit card or as a result of prolonged use. Sometimes operation resumes after a "cooling off" period. At others, the thermal overload shutdown is permanent.
Jan 17, 2013 | Office Equipment & Supplies
Staples SPL -TXC15A Shredder on all the time
This is what worked for me.
1) unplug the shredder
2) put the selector in "auto" position. This pulls back the guard which blocks the paper and hids the sensor.
3) a little right of the center of the paper slot is the sensor. You can feel this by inserting a cotton swab in ths slot.
4) put some alcohol on the cotton swab and clean the sensor!!!!
Also the "bin full" sensors are under the shretter head. You can easily see those when you remove the head from the bin by flipping it over. I would advise cleaning those while you are at it. Mine were covered with dirt and dust.
Hope this helps!!
Tommy
Sep 06, 2012 | Office Equipment & Supplies
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
STAPLES MODEL#SPL-826XSHREDDER
Cleaned the sensors with warm water and Q Tips. Works fine now..
For Staples shredder model #SPL-826X.
Thanks!
Apr 29, 2008 | Achiever SCS-6 Strip-Cut Shredder
jasbo
jasbo
