Question about Acer AX3400-U3032 Desktop - Black (PTSE202015)
Starts but fails to complete start - Acer AX3400-U3032 Desktop - Black (PTSE202015)
I have 2010 mercedes benz c180 it starts well after some kilometers it cuts as if no fuel then I stopped and re-start it goes well and cuts again only wen it is loaded when I am alone its fine help
Crankshaft Positioning Sensor Replacement
Problems with the Crankshaft Position Sensor (CPS) on Mercedes-Benz cars are fairly common. If you have been experiencing stalling or no start conditions, a failed crankshaft position sensor is often the problem. Your CPS may have failed if the engine cranks but it will not start. At first, you may experience no start conditions intermittently. As the crankshaft position sensor fails completely, the car will no longer start or will die when you are driving. Starting problems are initially random, but more frequent when the engine is hot. Other symptoms of a failed crankshaft position sensor are poor acceleration, engine vibrations, poor throttle response, bad fuel economy, hesitation, engine stalls. The engine starts if you let it cool down. If you are stuck on a parking lot and the car will not start, let the car cool down at least 30 minutes and then try again. ( Thanks to MB Medic)
Jun 23, 2017 | Mercedes-Benz C-Class Cars & Trucks
I have 2005 jeep liberty while driving it it died now won't start what could be wrong with it
There are many things that can cause this problem. You need to assess whether there is fuel and spark getting to the engine. IF one or the other is missing, the vehicle will not start. You can try retreving any trouble codes from the computer to see if it has stored a code for this problem. If no codes... possible fuel pump/filter/ crank sensor/wiring/computer/fuse just to name a few
Oct 03, 2015 | Jeep Cars & Trucks
Whirlpool WTW4910XQ0 locks and then unlocks when I try to start the machine
Controls rarely fail lid locl could be out of alignment or about to fail the fact you got 2 loads leans towards a lock assembly going bad they fail frequently
Feb 11, 2015 | Whirlpool Washing Machines
I have a honda vtec engine' my problem is evrytme i used my car in the morning, the engine will start nice, after i reused it again and start the engine, it wont start anymore, i did replace the spark...
There are some components that start to fail when hot before they fail completely. Most likely it is an ignition component, but you need to take basic troubleshooting steps to find the problem. Please read the notes at the ink below; and, When it fails to start, follow those notes to help find the issue.
Do It Yourself Diagnosis and Repair
Sep 08, 2017 | Cars & Trucks
Hp g56 some times it starts and other times it doesnt completely
Perhaps the HDD is failing? Reseat the Memory mods, remove and test the HDD. Has the AC jack been damaged due to pulling of the Cord? Is the battery a replacement? Has there been ANY damage? When it will not start what happens? Nothing? No response? Fan spin? LED's Blink? Sounds like a loose connection?
Mar 28, 2013 | HP Computers & Internet
My starter...can I tap it to start?
If you are trying to start the car, and the starter solenoid is hanging up, tapping on it sometimes frees it up enough to engage the starter motor to turn over the engine. This is a two person operation - one to turn the key, the other to tap on the starter/starter solenoid. The problem will only get worse - eventually, the solenoid or starter will fail completely. Best bet is to schedule a time to get it fixed instead of waiting for it to fail completely, likely at a bad time for you.
Dec 06, 2012 | 2004 Cadillac SRX
Printer fails to start
fails to start meaning? it doesnt turn on completely? power lights flash? epson printer ink
Nov 09, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Machine will not start up,battery is not working but machine usually runs from the mains,machine starts up but does not make it to the bios,no beeps are detected.
Machine doesnt give beep, if the battery completely fails, you system wont start in battery and will continue to run in the main, incidcating that the battery is failing...
PLease rate this solution
Thanks
Nov 15, 2009 | Acer Aspire 5720-6661 Notebook PC
Cant power on completely
try starting it in safe mode: when booting press F8 continuously until you hear a beep. When/if it can start in safe mode go to Start>programs>accessories>system tools>system restore; and choose a date when you know your computer was working okay then press restore. When it has finished it will reboot, if it asks you what mode you want to use to start press start windows normally.
fingers crossed this will work. hope it helps
Jun 22, 2008 | Toshiba Satellite 5105-S501 Notebook
Acer AX3400-U3032 Desktop - Black (PTSE202015) Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
