Question about Arris SURFboard SB4220 Modem
Motorola surfboard router is blocking webcam - Arris SURFboard SB4220 Modem
Blocking specific websites
Hello you can actually block web sites on your computer but no on your router because it Is just for Internet transmitting so it does not have a memory so if you want to block some thing you can do it on your computer.
Apr 17, 2012 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
How do I block facebook from my Motorola router?
http://broadband.motorola.com/noflash/customer_docs/user_guides/507755-001.pdf Please go through this article .In this article Basic configuration>Setting the firewall policy>firewall policy advance page.
Jul 28, 2011 | Arris SURFboard SBG900 Wireless Router...
I have a Magic jack internet phone well my router firewall seems to be blocking it how can i exclude it from the firewall in my router?
MagicJack uses port 5060 & 5070 UDP. so go into your router and select port forwarding or applications something along those lines and insert the correct ports into the configuration. it should be pretty self explanatory. i'm not familiar with this particular model of router. if you need instructions they can be found here: http://broadband.motorola.com/noflash/customer_docs/user_guides/506705-001.pdf
if however your ISP is blocking the use of magic jack there isn't alot you can do about it
Dec 31, 2010 | Arris SURFboard SBG900 Wireless Router...
What type of wifi router should I buy
you can add any router you want. since the surfboard is just a modem, you can add any router you want. just make sure that after you plugin a router into the surfboard, that you disconnect the surfboard from it's power, wait 10 seconds and then reconnect the power. this is to let the surfboard see the router since it is known to remember it's last connected device.
Apr 08, 2010 | Arris SURFboard® SB5101 Cable Modem
Can not connect web cam and view outside of home network
Try to see your modem config and send the data.
regards
Jan 06, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SB4220 Modem Logo
21 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
