Question about Lafer Furniture
I want to repad the Lafer "Billie" Recliner we have had this model since 2003 and the padding is breaking down after LOTS of wonderful use.
2 Suggested Answers
  • 16 Answers
SOURCE: Bleeding the brakes after new pads are installed...
On the backside of the brake backing plate there is a bleeder valve that looks more like a grease fitting. Someone needs to be in the vehicle with motor running, pump the brake twice and hold pedal down on the third pump while another person takes a small wrench or socket and loosens the bleeder valve, if no fluid comes out or it spurts, tighten the valve and repeat process until nothing but fluid comes out, do the same for the other wheel, keeping check on the fluid level in the master cylinder at the booster ( if equipped)
Posted on Jul 14, 2010
What address do I use to return an item (masssge
you need to contact them before you even think about the address as they will provide you with it .
Feb 12, 2015 | Comfort Products Relaxzen Deluxe Padded...
Lafer spring
I have Lafer Kiri chair and spring for foot rest broke
i found replacement spring at Lowes
It is Hillman replacement spring 2 per pkg
Bar code 08236 80104
Works great
Nov 30, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
The spring snapped on lafer recliner chair
I bought replacement spring at Lowes
This was Hillman brand replacement spring
Five eight x three and a quarter x 072 inch type
2 springs per pkg works great
Apr 06, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
Ink pads are going
heartland America bottles of ink
if you mean to say out of ink go thiere web site repad
question you dont need pads you want ink is that rightpart number and you order padsoffice max
Feb 16, 2012 | Office Equipment & Supplies
2003 rav 4 2 ltr petrol changed front discs and pads now have lots of high pitch noise have taken apart and used lots of copper slip and its still happening talked to local toyota garage who said i mave...
someones trying to pull your chain.....the pads fit both sides of the disc(rotor)BUT if the discs were scored then the noise is the pads trying to bed into the scores/ridges....if you can feel a ridge of more than 1mm on the outer edge then you should replace the discs.(dont bother to undercut)then you would have no noise at all.as a matter of interest the front discs last no more than 30.000 miles.fact...unless you use the gearbox to slow down and not the brakes.then 40.000.
Sep 18, 2010 | 2003 Toyota RAV4
2003 Kia Sedona Ex. Squeaks when brakes
Most likely, there are metal peaces on the break pad, for when the pads get wore down to a certain point they rub the rotor to let you know its time for new breaks.
Mar 25, 2009 | 2003 Kia Sedona
Brake light on my instrument panel
this may also be a waring to let you know that you need new break pads this is easy to check
  1. jack up your car and take one of the front wheels off
  2. near the disk that you can see there is a thing called a caliper
  3. in between there and the caliper look to see if there is anything there
  4. if there is it should not be any thinner the 5mm
if there is no pads you can be up for lots of money if you drive around
your disks will have grooves in them which is not good and you rick boiling your break fluid
if this dose not help then one of the sensors could be broken or the control unit could be busted
Dec 27, 2008 | 2001 Dodge Ram 1500 Truck 2WD
Help! Yellow note pad everywhre.
There is a program called Ink - you'll find it in your system preferences under the apple menu. You need to turn it off. This will allow you to use your wacom without that annoying yellow notepad everywhere!!
Oct 05, 2008 | Wacom Intuos3 Graphic Tablet
Furniture Logo
166 people viewed this question
Top Lafer Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Lafer Furniture Expert? Answer questions, earn points and help others
